楼主: Ant_liu
山东烟台外资汽配新工厂招聘热处理工艺工程师
发表于 2012-11-14 18:41:42 | 显示全部楼层
Ant_liu 发表于 2012-11-14 18:34
杨工,你的链接打不开啊
    惭愧,这个http://www.rclbbs.com/forum.php? ... 8&fromuid=31405可以打开,但内容有些老旧
 楼主| 发表于 2012-11-14 18:44:58 | 显示全部楼层
杨工,你的链接打不开啊
杨工确实很优秀啊,很高兴认识您老乡!
发表于 2012-11-14 17:52:58 | 显示全部楼层
    楼主看看我http://www.microscopy.com.cn/for ... 7&fromuid=51081是否满足要求?除了缺少外语这把利器,其它方面还凑合
发表于 2012-11-14 18:17:11 | 显示全部楼层
孤鸿踏雪 发表于 2012-11-14 17:52
楼主看看我http://www.microscopy.com.cn/forum.php?mod=viewthread&tid=6297&fromuid=51081是否满足要 ...
不会吧,杨工对这职位感兴趣?
签到天数: 105 天
发表于 2012-11-14 14:26:30 | 显示全部楼层
               应聘……
 楼主| 发表于 2012-11-14 13:08:51 | 显示全部楼层 |阅读模式
Senior heat treatment Engineer
- Manufacturing Engineering –
Job requirements:
•        University degree in material engineering or related heat treatment technical degree;
•        At least 3 years practical working experience;
•        Technical knowledge:
- Good knowledge of heat treatment equipment and process, such as carburization, quenching, deep cooling, etc.
- DLC coating experience is a plus.
- Able to read different microstructures under microscope and know well microstructure transforming and character change during heating and cooling, able to figure out the cause of failed parts in production via complex test result from Lab;
•        Proactive, good team spirit and communicative skills to carry out cross-department project,
Good communication and interpersonal skills, excellent analytical skills, strong personal initiative, careful, considerate, and diligent;
•        Be familiar with APQP, PPAP, FMEA, MSA, SPC, 8D quality tools;
•        PC skills: MS Office;
•        Good English/French language for a technical dialog;
•        General knowledge about the functioning of pump/injector is a plus;
•        Travel abroad is required.
Responsibilities:
•        Prepare documents to support production as working instructions, production routing, process, quality checking inspection and control plan;
•        Set up the documentation of lab process and working instruction. Supervise the compliance operation;
•        Provide technical support for out sourcing parts;
•        Provide support for training and validation operators and setters to achieve the manufacturing and quality goal;
•        Accomplish other assigned task to support operational excellence such as 6 sigma, TS16949, cost down etc.
Please send your CV to "ant.zz@genhr.com".
GMT+8, 2025-7-15 04:06 , Processed in 0.055126 second(s), 21 queries .
