查看: 7093|回复: 2
[Translation] Heat Treatment English
发表于 2005-11-30 23:31:26 | 显示全部楼层 |阅读模式
controlled cooling from casting and naturally aged
solution heat treated and naturally aged
controlled cooling from casting and naturally aged or over-aged
solution heat treated and fully artificially aged
solution heat treated and artificially under-aged
solution heat treated and artificially over-aged(stabilised)
签到天数: 18 天
发表于 2005-12-1 01:38:41 | 显示全部楼层
铸件强制冷却和自然时效
固溶热处理和自然时效
铸件强制冷却和自然时效或过度时效
固溶热处理和完全人工时效
固溶热处理和人工欠时效
固溶热处理和人工过度时效(使稳定)
wangqinghua196 + 5 有效答疑!
发表于 2009-4-2 16:41:24 | 显示全部楼层
用控制冷却比较恰当
GMT+8, 2026-1-30 10:19 , Processed in 0.046595 second(s), 23 queries .
