查看: 5361|回复: 0
深冷处理对20CrMnTi钢渗碳齿轮硬度和残余奥氏体评定的影响
发表于 2008-7-14 21:17:04 | 显示全部楼层 |阅读模式
【文章名称】:深冷处理对20CrMnTi钢渗碳齿轮硬度和残余奥氏体评定的影响
【发表期刊】:<<理化检验-物理分册 >>2000年03期
【作者】:施友方
【摘要】:20CrMnTi钢渗碳齿轮最表层硬度偏低,系残余奥氏体量过多所致。通过深冷处理可使部分残余奥氏体转变成马氏体,从而提高了表面硬度。对金相法评定残余奥氏体的局限性进行了探讨。
Lower surface layer hardness in carburized 20CrMnTi gear was a result of excesssive amount of retained austeaite.A study was wade to increase its surface layer hardness by subzero treatment, during which re-tained austenite transformed into martensite. A discussion was made on limitation of metallographic evaluation of retained austenite.
【关键词】:硬度 有效硬化层深度 深冷处理 马氏体 残余奥氏体
GMT+8, 2026-1-31 13:35 , Processed in 0.044451 second(s), 23 queries .
