查看: 23357|回复: 3
[Help] What kind of preparation need to do for Nadcap Audit ?
签到天数: 96 天
发表于 2018-12-28 09:31:18 | 显示全部楼层 |阅读模式
Dears
       Would you like to share your experence that if we change the instrument type from A to B,
        what kind of preparation shall we do for the Nadcap audit?
        What potential riks will we have to face?
Thanks very much in advance for your sharing.
BRs
Lucy
签到天数: 27 天
发表于 2019-4-23 14:16:26 | 显示全部楼层
Review the difference between type A and B firstly.
Analyse the risk if you replace A by B.
Produce some batch parts and check the property. If OK, do it.
参与人数 1热处理币 +20 贡献值 +50 收起 理由
cjzhou + 20 + 50 感谢支持!
签到天数: 159 天
发表于 2019-6-23 13:03:49 | 显示全部楼层
From my side, it's improvement that you change instrument from A to B.
And analyze the result , compare the risk of A and B.
last do the test and analyze the result.
chenze2008 + 20 + 50 感谢参与!
签到天数: 34 天
发表于 2019-7-18 13:36:24 | 显示全部楼层
You should consult some certification experts
GMT+8, 2025-6-28 11:42 , Processed in 0.046105 second(s), 22 queries .
