查看: 5659|回复: 1
[求助] 哪里能够按照DIN 50602:1985 测试非金属夹杂含量
签到天数: 7 天
发表于 2009-1-12 22:29:14 | 显示全部楼层 |阅读模式
Size: OD 50mm Bar
Material Mark: H13(ESR)
Requirements:
DIN 50602-K1
and the following provisions:
1, test result should be issued in accrodance with table 8 of DIN 50602;
2, the quanity of specimens should be 6, the area of each specimen for evaluation should be not less than 300mm2;
3, the specimens after testing should return.
please furnish the offer informtion, including test total price, test duration.
发表于 2009-1-13 15:16:08 | 显示全部楼层
上海材料研究所
首钢研究所
兴澄钢厂
上钢五厂
东北特钢
上述单位或许可以
GMT+8, 2025-7-10 11:53 , Processed in 0.042428 second(s), 21 queries .
