查看: 6651|回复: 0
ASTM A 437/A 437M-01a Standard Specification for Alloy-Steel Turbine-Type Boltin
发表于 2007-6-27 08:16:32 | 显示全部楼层 |阅读模式
ASTM A 437/A 437M-01a Standard Specification for Alloy-Steel Turbine-Type Bolting Material Specially Heat Treated for High-Temperature Service
ASTM A 437/A 437M-01a 高温设备用经特殊热处理的涡轮型合金钢螺栓材料标准规范
GMT+8, 2026-1-30 05:36 , Processed in 0.042507 second(s), 22 queries .
