查看: 3726|回复: 0
Fick's Laws of Diffusion
发表于 2010-9-16 15:35:12 | 显示全部楼层 |阅读模式
By Paul A. Steward.
Diffusion is the mechanism by which components of a mixture are transported around the mixture by means of random molecular (Brownian) motion (cf. permeation: the ability of a diffusant to pass through a body - dependent on both the diffusion coefficient, D, and the solubility coefficient, S, ie, permeability coefficient, P = D.S). Flynn et al. cite Berthalot as postulating, at the beginning of the nineteenth century, that the flow of mass by diffusion (ie, the flux), across a plane, was proportional to the concentration gradient of the diffusant across that plane.
[url=]In the mid-1800's,[/url]Fick introduced two differential equations that quantified the above statement for the case of transport through thin membranes. Fick's First Law states that the flux, J, of a component of concentration, C, across a membrane of unit area, in a predefined plane, is proportional to the concentration differential across that plane (see note), and is expressed by:
Fick's Second Law states that the rate of change of concentration in a volume element of a membrane, within the diffusional field, is proportional to the rate of change of concentration gradient at that point in the field, as given by:
where t = time.
Adapted from: Modification of the Permeability of Polymer Latex Films., Nottingham Trent University PhD Thesis, 1995.
Copyright © Paul Steward, 1995.
GMT+8, 2026-1-29 06:48 , Processed in 0.040613 second(s), 21 queries .
