查看: 8998|回复: 6
[求助] 日本Nihon Parkerzing的低温Palsonite盐浴氮碳共渗技术求助!
发表于 2012-10-3 13:37:48 | 显示全部楼层 |阅读模式
了解到这个低温渗氮技术采用盐浴氮碳共渗,温度450~490℃,还有他们公司的一点介绍,有谁了解该技术的更为详细的内容,大家可以交流,谢谢!
 楼主| 发表于 2012-10-3 13:38:41 | 显示全部楼层
一点介绍:Our surface treatment chemicals work to protect a variety of materials including steel, aluminium and non-ferrous metals from the damaging and costly effects of rust and corrosion, and are essential for improving the quality and coating performance of subsequent painting. Nihon Parkerizing Co., Ltd. is a Japan-based manufacturer of chemical agents and equipment. The Company operates in four business segments. The Chemical Agents segment manufactures and sells metal surface treatment chemicals, corrosion-prevention chemicals, rolling mill lubricant, coating materials, electroless nickel plating and industrial detergents. The Equipment segment manufactures and sells metal surface treatment equipment and coating equipment. The Processing segment is engaged in the provision of anti-rust processing service and heat treatment processing service. The Others segment is involved in the maintenance work of buildings, the manufacture and sale of metal specimen plates, the management and leasing of real estates, as well as the sale of petroleum products and the brokerage of industrial waste disposal.Our specialty is the development of surface hardening technology including heat treatments (carburizing, nitriding, sulfurizing) and composite nickel plating. We have developed a low temperature salt bath nitriding (Palsonite) which is energy saving and low distortion. Furthermore, we have established a salt bath nitriding system in which the cyanide generation during the nitriding reaction is less than 1wt%.
签到天数: 2271 天
发表于 2012-10-3 14:56:14 | 显示全部楼层
套用杨工的话,所谓曲高和寡。
签到天数: 2800 天
发表于 2012-10-7 08:01:38 | 显示全部楼层
以前我经常看日文杂志,现在看不到啦!楼主所说的是450-490C的盐浴低温氮碳共渗。
发表于 2012-10-9 10:26:33 | 显示全部楼层
txljh8 发表于 2012-10-3 14:56
套用杨工的话,所谓曲高和寡。
   阳春白雪啊
发表于 2012-10-8 11:04:27 | 显示全部楼层
现在他们已经准备用尼萃斯的气体氮化技术了,在广东做的。
签到天数: 114 天
发表于 2018-10-19 14:25:07 | 显示全部楼层
低温氮化工艺很成熟了已经
GMT+8, 2026-7-19 01:48 , Processed in 0.029887 second(s), 21 queries .
