查看: 4907|回复: 0
[求助] 上海长方光学仪器有限公司 倒置式生物显微镜
发表于 2007-12-14 10:07:40 | 显示全部楼层 |阅读模式
http://www.chfang.com/produce/biology/XSP17C.htm 倒置式生物显微镜xsp-17c
http://www.chfang.com/produce/biology/XSP18C.htm 倒置生物显微镜XSP-18C
http://www.chfang.com/produce/biology/XSP19C.htm 电脑倒置生物显微镜XSP-19C
http://www.chfang.com/produce/biology/XSP20C.htm 研究级倒置生物显微镜XS-P20C
http://www.shchfang.com/biology/XSP15C.htm 倒置生物显微镜XSP-15C
http://www.shchfang.com/biology/XSP17C.htm 倒置式生物显微镜XSP-17C
http://www.shchfang.com/biology/XSP18C.htm 电脑倒置生物显微镜XSP-19C
http://www.shchfang.com/biology/XSP20C.htm 研究级倒置生物显微镜XSP-20C
http://www.68610299.com/produce/biology/XSP-15C.html 倒置生物显微镜XSP-15C
http://www.68610299.com/produce/biology/XSP-17C.html 置式生物显微镜XSP-17C
http://www.68610299.com/produce/biology/XSP-18C.html 上海生物显微镜XSP-18C
http://www.68610299.com/produce/biology/XSP-18C.html 倒置生物显微镜XSP-18C
http://www.68610299.com/produce/biology/XSP-19C.html 电脑倒置生物显微镜XSP-19C
http://www.68610299.com/produce/biology/XSP-20C.html 研究级生物倒置显微镜XSP-20C
http://www.chfang.com/produce/biology/XSP17C.htm倒置式生物显微镜xsp-17c
http://www.chfang.com/produce/biology/XSP18C.htm倒置生物显微镜XSP-18C
http://www.chfang.com/produce/biology/XSP19C.htm电脑倒置生物显微镜XSP-19C
http://www.chfang.com/produce/biology/XSP20C.htm研究级倒置生物显微镜XS-P20C
http://www.shchfang.com/biology/XSP15C.htm倒置生物显微镜XSP-15C
http://www.shchfang.com/biology/XSP17C.htm倒置式生物显微镜XSP-17C
http://www.shchfang.com/biology/XSP18C.htm倒置生物显微镜XSP-18C
http://www.shchfang.com/biology/XSP19C.htm电脑倒置生物显微镜XSP-19C
http://www.shchfang.com/biology/XSP20C.htm三究级倒置生物显微镜XSP-20C
http://www.68610299.com/produce/biology/XSP-15C.html倒置生物显微镜XSP-15C
http://www.68610299.com/produce/biology/XSP-17C.html倒置式生物显微镜XSP-17C
http://www.68610299.com/produce/biology/XSP-18C.html上海生物显微镜XSP-18C
http://www.68610299.com/produce/biology/XSP-18C.html倒置生物显微镜XSP-18C
http://www.68610299.com/produce/biology/XSP-19C.html电脑倒置生物显微镜XSP-19C
http://www.68610299.com/produce/biology/XSP-20C.html研究级生物倒置显微镜XSP-20C
二、系统简介
   倒置式生物显微镜系统是将精密的光学显微镜技术、先进的光电转换技术与尖端的计算机图像处理技术完
 美地结合在一起而开发研制成功的一项高科技产品。可以在显示屏上很方便地观察实时动态图像,并能将所需要
 的图片进行编辑、保存和打印。
三、技术参数
  1.目镜
类 别 放大倍数 视场直径(mm)
大视野目镜 10X φ18
20X φ11
  2.物镜
类 别 放大倍数 数值孔径(NA) 工作距离(mm) 盖玻片厚度(mm)
长工作距离平场
消色差物镜 PLL10X 0.25 8.1 1.2
PLL25X 0.40 4.8 1.2
PLL40X 0.60 3.3 1.2
长工作距离相衬物镜 PLL10X 0.25 8.1 1.2
PLL25X 0.40 4.8 1.2
PLL40X 0.60 3.3 1.2
  3.光学放大倍数:100X-400X
  4.系统参考放大倍数:40X-2600X
  5.聚光镜:特长工作距离聚光镜: 工作距离:50mm
   超长工作距离聚光镜: 工作距离 70mm
  6.机械载物台:尺寸:200mm * 140mm;移动范围:30mm * 75mm
   载物板可直接放置 96 孔培养器皿,并配置多种载物板用于不同的培养器皿
  7.调焦机构:同轴粗微动调焦机构,微动格值 0.002mm
  8.光源:30W 钨卤素灯,亮度可调
  9.防霉:特有的防霉系统
http://www.chfang.com.cn/produce/biology/XSP15CE.htm倒置生物显微镜XSP-15CE
http://www.chfang.com.cn/produce/biology/XSP17CE.htm倒置生物显微镜XSP-17CE
http://www.chfang.com.cn/produce/biology/XSP18CE.htm数码倒置生物显微镜XSP-18CE
 四、系统组成
  电脑型倒置生物显微镜: 1、显微镜  2、适配镜  3、摄像器(CCD)
                    4、A/D(图像采集)    5、计算机
  数码型倒置生物显微镜: 1、显微镜  2、适配镜  3、数码相机
 五、仪器选购件
  1.目镜:16X 20X      2.物镜:25X 40X(长工作距离相衬物镜)
  3.高像素成像系统      4.图像分析软件
     [http://www.chfang.com.cn/] 显微镜[/url
[http://www.shchfang.com/hot.htm] 显微镜 [/url
[http://www.68610299.com/fluoro.htm] 显微镜[/url
[http://www.68610299.com/] 显微镜 [/url
[http://www.shchfang.com/ ]显微镜[/url
[http://www.chfang.com.cn/produce/metal.htm] 金相显微镜 [/url
[http://www.68610299.com/metal.html] 金相显微镜 [/url
[http://www.chfang.com.cn/] 金相显微镜 [/url
[http://www.68610299.com/read.html] 金相显微镜 [/url
[http://www.shchfang.com/metal.htm] 金相显微镜 [/url
[http://www.shchfang.com/metal/4XC.htm] 金相显微镜 [/url
[http://www.chfang.com.cn/produce/polarze.htm] 偏光显微镜[/url
[http://www.shchfang.com/polarze.htm] 偏光显微镜 [/url
[http://www.68610299.com/polarze.html] 偏光显微镜 [/url
[http://www.68610299.com/phase.htm] 偏光显微镜[/url
[http://www.shchfang.com/phase.htm] 偏光显微镜 [/url
[http://www.chfang.com.cn/] 偏光显微镜 [/url
[http://www.chfang.net/pg2.htm] 偏光显微镜[/url
[http://www.chfang.com.cn/produce/biology.htm] 生物显微镜[/url
[http://www.68610299.com/biology.html] 生物显微镜 [/url
[http://www.chfang.net/] 生物显微镜 [/url
[http://www.68610299.com/ 生物显微镜[/url
[http://www.68610299.com/stereo.html] 体视显微镜 [/url
[http://www.68610299.com/biology.html] 体视显微镜 [/url
[http://www.chfang.com.cn/produce/stereo.htm] 体视显微镜[/url
[http://www.shchfang.com/stereo.htm] 体视显微镜 [/url
[http://www.chfang.com.cn/produce/fluoro.htm] 荧光显微镜[/url
[http://www.chfang.com.cn/produce/produce.htm] 荧光显微镜 [/url
[http://www.68610299.com/fluoro.html] 荧光显微镜 [/url
[http://www.68610299.com/] 荧光显微镜[/url
[http://www.shchfang.com/] 荧光显微镜[/url
[http://www.shchfang.com/fluoro/CFM500.htm] 荧光显微镜 [/url
[http://www.chfang.com.cn/produce/read.htm] 读数显微镜 [/url
[http://www.shchfang.com/read.htm] 读数显微镜[/url
[http://www.68610299.com/read.html] 读数显微镜 [/url
[http://www.68610299.com/measure.html] 测量显微镜 [/url
[http://www.shchfang.com/measure.htm] 测量显微镜 [/url
[http://www.chfang.com.cn/produce/cube.htm] 立体显微镜 [/url
[http://www.68610299.com/cube.html] 立体显微镜 [/url
[http://www.shchfang.com/cube.htm] 立体显微镜 [/url
GMT+8, 2026-6-15 19:57 , Processed in 0.027083 second(s), 22 queries .
