查看: 8017|回复: 13
[讨论] 有用过SteCal软件的吗
发表于 2013-3-26 15:59:30 | 显示全部楼层 |阅读模式
如题 有用过SteCal软件的吗
 楼主| 发表于 2013-3-26 17:39:40 | 显示全部楼层
HRC 发表于 2013-3-26 17:06
这个软件是干什么的?
a program to predict the properties of steel 自己百度翻译吧
签到天数: 809 天
发表于 2013-3-26 17:06:04 | 显示全部楼层
这个软件是干什么的?
签到天数: 118 天
发表于 2013-4-2 03:21:24 | 显示全部楼层
我用过,有问题吗?
签到天数: 118 天
发表于 2013-4-12 04:24:38 | 显示全部楼层
Description
SteCal 3.0 is a program for predicting the properties obtained from heat treating low-alloy steels. Available for the first time in user-friendly Microsoft Windows format, SteCal calculates the parameters and behavioral properties representative of low-alloy steels, and predicts the effects of heat treating such steels. It is an excellent tool for heat treaters to use in estimating and refining heat treating parameters for unfamiliar steels. SteCal is also useful for comparing the properties of two steels of different composition, which can help to suggest the most appropriate composition for a particular application. SteCal is based on the most effective and precise heat treating calculation routines available. SteCal can be used to predict heat treating data such as lower critical temperature, critical point of heating, highest feasible tempering temperature, austenitizing temperature, susceptibility to quench cracking, and hardness obtained from various treatments. The program can be used to generate CT diagrams, IT diagrams, hardness versus tempering curves (with calculated tensile strength, yield strength, and elongation values), and Jominy end-quench hardenability curves. Data can be viewed as graphs or tables.
SteCal 3.0 is compatible with Windows XP and Windows 7.
Publisher: ASM International, 2004
ISBN: 978-0-87170-796-3
发表于 2013-4-11 21:11:44 | 显示全部楼层
metart 发表于 2013-4-2 03:21
我用过,有问题吗?
介绍一下,我没有听说过,能否介绍一下呢?
发表于 2013-4-12 08:01:07 | 显示全部楼层
是热处理模拟软件么?
发表于 2013-4-12 21:15:15 | 显示全部楼层
metart 发表于 2013-4-12 04:24
Description
SteCal 3.0 is a program for predicting the properties obtained from heat treatin ...
I have a impression on ASM for the software。
签到天数: 118 天
发表于 2013-4-12 21:51:18 | 显示全部楼层
mamstein 发表于 2013-4-12 08:01
是热处理模拟软件么?
开玩笑,模拟软件哪有这么便宜的,一般都是上万甚至十几万美元,只有公司才肯花这么多钱。
发表于 2013-4-12 22:02:48 | 显示全部楼层
尝试下载free,i can not find it。
签到天数: 118 天
发表于 2013-4-12 22:07:10 | 显示全部楼层
大家都这样,那谁还做软件?像这种软件本来买的人就少,如果到处有免费下载,那人家干脆关门不干了。
发表于 2013-4-12 22:09:08 | 显示全部楼层
电脑发明起就有一个“共享”的功能,我觉得我就是这类人,i have no money,so...
签到天数: 48 天
发表于 2013-4-12 22:44:37 | 显示全部楼层
字字看来皆是血,十年辛苦不寻常呀,
签到天数: 118 天
发表于 2013-4-13 12:18:54 | 显示全部楼层
你自己的东西跟人家“共享”是你的事,但你没有跟人家共享不是你的东西的权力。没有钱可以,但不能没志气。
中国在知识产权保护方面执法不严,到头来是害了自己。
GMT+8, 2026-5-19 00:27 , Processed in 0.033956 second(s), 21 queries .
