查看: 9308|回复: 1
[Translation] standard sentence
签到天数: 18 天
发表于 2013-12-31 16:43:53 | 显示全部楼层 |阅读模式
pls someone can help translate the sentence from standard as below
" it is not allowed to use end bloom(s) of a heat because these already show the chem. composition of the next heat(difference in the elements Si,Cu,Ni,Mo,Al etc.)"
thanks in advance
签到天数: 203 天
发表于 2014-1-1 00:36:33 | 显示全部楼层
Try to translate as below:
不得采用一个炉批的末个(或末几个)钢坯,因为这些钢坯已显现出下一个炉批的化学成分(Si,Cu,Ni,Mo,Al 等元素不同)。
chenze2008 + 10 感谢参与!
GMT+8, 2026-7-16 19:40 , Processed in 0.027435 second(s), 22 queries .
