查看: 7963|回复: 3
德国schwartz炉子:燃烧器 剖面 炉体
发表于 2008-3-12 15:45:19 | 显示全部楼层 |阅读模式
Gas-tight roller he
arth furnace lines
[ 本帖最后由 xuhcqr 于 2008-3-21 10:11 编辑 ]
 楼主| 发表于 2008-3-14 15:02:21 | 显示全部楼层
性能
Applications: annealing, hardening, forging, sintering, tempering of metals, heat treatment of glass and ceramics
应用:退火,淬火,锻造,烧结,回火,玻璃和陶瓷的热处理
Roller hearth furnace 辊底式炉
with complete feeding system for heat treatment in protective atmospheres at up to 1,200°C
带完整的保护气氛热处理输送系统温度最高1200°C
Easy integration of these furnace systems into any existing production line.
这些炉子系统很容易集成进现存的任何生产线。
Highest flexibility in material flow and process engineering
材料流动和工艺的工程学的高柔性
Jet cooling with protective atmosphere (optional)
喷淋冷却带保护气氛(可选)
Ceramic conveying rollers, steel tubes and product carriers ensure excellent reliability in operation
陶瓷输送辊,钢管和产品输送保证了极好的操作可靠性。
schwartz hearth roller modules mean low cost and very little maintenance
Schwartz辊底式模式意味着低的费用和非常少的维护。
 楼主| 发表于 2008-3-14 15:04:31 | 显示全部楼层
性能
Benefits and features of schwartz roller hearth furnaces Schwartz辊底式炉的利益和特点
Feeding and discharge lock chambers with sliding doors suitable for feeding large
product into protective atmosphere furnaces
输送和卸料锁室带滑门,适合输送到大的制件进入保护气氛炉。
Atmosphere input system for various heat treatment needs, including furnace atmosphere monitoring and control features
气氛输入系统对于各种各样的热处理需要,包括炉子气氛监控和控制炉子;
Various heating systems (electrical, gas-fired, or a combination of b
oth)
各种各样的加热系统(电,燃气,或者两者组合式)
Optional off gas incinerator
可任选的气态废物焚烧装置。
Fully monitored heat treatment process with parameter and alarm logging, visual display and communication with host control systems through appropriate system configuration
全程监控热处理工艺参数并记录报警,真实显示并与主控制系统的进行通信,通过适当的系统配置。
 楼主| 发表于 2008-3-14 15:05:13 | 显示全部楼层
规格
Specifications:规格
Useful width :有效宽度        infinitely variable, up to 2,000 mm 无穷变量 直到2000mm
Useful length :有效长度        to suit any requirements 可到任何需要的长度
Roller diameter: 棍子直径        20 to 200 mm 20~200mm
Mode of heating:
加热模式:        electrical, gas-fired, or a combination of both
电,燃气 或者两者组合式
Temperature range:
温度范围:
        up to 1,450°C
直到1450°C
GMT+8, 2026-7-19 07:20 , Processed in 0.030202 second(s), 24 queries .
