查看: 4855|回复: 1
[求助] KIC 测试中的预制裂纹后拉断的速率转换
发表于 2014-8-20 16:58:52 | 显示全部楼层 |阅读模式
Loading Rate—For conventional (quasi-static) tests, the specimen shall be loaded such that the rate of increase of stress-intensity factor is between 0.55 and 2.75 MPa√m/s (30 and 150 ksi√in./min) during the initial elastic displacement.
中的0.55-2.75 MPa√m/s  怎么转换成 mm/s 的单位。
求大神指教,详细的计算方法跟原理!
 楼主| 发表于 2014-8-21 10:54:48 | 显示全部楼层
有同学和老师研究过断裂韧性测试的吗
GMT+8, 2026-6-22 18:01 , Processed in 0.026839 second(s), 21 queries .
