查看: 5167|回复: 3
[已解决] 新的提醒打不开怎么回事啊?
签到天数: 118 天
发表于 2015-4-29 18:51:59 | 显示全部楼层 |阅读模式
Discuz! Database Error
(145) Table '.\ultrax\home_notification' is marked as crashed and should be repaired
SELECT COUNT(*) FROM home_notification WHERE uid=75254 AND `type`='post'
PHP Debug
No.        File        Line        Code
1        home.php        41        require_once(%s)
2        source/module/home/home_space.php        116        require_once(%s)
3        source/include/space/space_notice.php        104        table_home_notification->count_by_uid(%s, %d, %s, %s)
4        source/class/table/table_home_notification.php        102        discuz_database::result_first(%s, Array)
5        source/class/discuz/discuz_database.php        117        discuz_database::query(%s, Array, false, false)
6        source/class/discuz/discuz_database.php        136        db_driver_mysql->query(%s, false, false)
7        source/class/db/db_driver_mysql.php        153        db_driver_mysql->halt(%s, %d, %s)
8        source/class/db/db_driver_mysql.php        224        break()
www.rclbbs.com 已经将此出错信息详细记录, 由此给您带来的访问不便我们深感歉意. Need Help?
签到天数: 2946 天
发表于 2015-4-30 08:48:21 | 显示全部楼层
用户通知的数据库出现错误,现已修复
签到天数: 118 天
 楼主| 发表于 2015-4-30 11:50:04 | 显示全部楼层
原来如此,CEO辛苦了!
GMT+8, 2026-7-18 18:18 , Processed in 0.028317 second(s), 21 queries .
