查看: 9529|回复: 2
[Discussion] What's the difference between shot blasting and shoot peening?
发表于 2015-6-11 11:09:14 | 显示全部楼层 |阅读模式
cjzhou + 5 good topic
签到天数: 329 天
发表于 2015-7-6 10:46:42 | 显示全部楼层
Check these two terminology from Wikipedia.
For shot blasting: Abrasive blasting(redirect from shot blasting) is the operation of forcibly propelling a stream of abrasive material against a surface under high pressure to smooth a rough surface, roughen a smooth surface, shape a surface, or remove surface contaminants. A pressurized fluid, typically air, or a centrifugal wheel is used to propel the blasting material (often called the media). The first abrasive blasting process was patented by Benjamin Chew Tilghman on 18 October 1870.[1]
There are several variants of the process, such as bead blasting, sand blasting, sodablasting, and shot blasting.
For shot Peening. Shot peening is a cold working process used to produce a compressive residual stress layer and modify mechanical properties of metals. It entails impacting a surface with shot (round metallic, glass, or ceramic particles) with force sufficient to create plastic deformation.[1][2]
It is similar to sandblasting, except that it operates by the mechanism of plasticity rather than abrasion: each particle functions as a ball-peen hammer. In practice, this means that less material is removed by the process, and less dust created.
So, generally, shot blasting will be focused on cleaning/abrasion, but for shot peening, it will focus on plastic deformation to form a residual stress.
Thank you Zluu22, you raised a good question, and I learned a lot.
cjzhou + 10 感谢支持!
 楼主| 发表于 2015-7-16 09:38:03 | 显示全部楼层
Thank you very much!
参与人数 1热处理币 +3 收起 理由
cjzhou + 3 感谢参与!
GMT+8, 2026-6-28 16:12 , Processed in 0.028319 second(s), 22 queries .
