查看: 10271|回复: 1
[分享] furnace 的解释及特殊用法
签到天数: 10 天
发表于 2008-5-16 08:36:39 | 显示全部楼层 |阅读模式
现代英汉综合大辞典
furnace
[5fE:nis]
n.
(1)
炉子; 熔炉; 高炉
(2)
窑, 燃烧室, 暖气炉; 锅炉
(3)
反应堆
(4)
极热的地方
(5)
考验; 磨炼
an atomic [a nuclear] furnace
原子反应堆, 核反应堆
blast furnace
【冶】鼓风炉, 高炉
词性变化
furnace
[5fE:nis]
vt.
在炉中烧热, 煅[焙]烧, 炉内熔化, 磨炼
继承用法
furnace-cooled
adj.
炉内冷却的
furnace-heating
n.
暖气炉; 暖房法
furnaceoperator
n.
炉工, 熔炼工
furnacestat
n.
炉稳定器
furnaceman
n.
炉前工
furnacelike
adj.
习惯用语
be tried in the furnace
受磨炼
特殊用法
acid open-hearth furnace
酸性敞炉
air furnace
鼓风炉
air-arc furnace
空气电弧炉
air heating furnace
热风炉
Ajax-Northrup furnace
(阿加克斯-闹斯拉普)高频感应炉(无铁心高频感应炉)
Ajax-Wyatt furnace
(阿加克斯-瓦依亚特)低频感应电炉
all-radiant furnace
辐射炉(无对流加热部分)
alloying furnace
合金炉
aludel furnace
梨坛炉(炼汞炉)
amco type tank furnace
双碹顶池窑
annealing furnace
退火炉
annular furnace
环形炉
arch furnace
拱顶炉
Arsem furnace
碳粒发热体电炉
assay furnace
试金炉; 验定炉
automatic metal feeding furnace
金属自动浇铸炉, 自动加(金属)料炉
auxiliaryfurnace
辅助熔炉
Bailyfurnace
贝利炭粒炉
bake outfurnace
烘箱, 烘烤炉
bale-out furnace
固定式坩埚炉(勺取)
bale-out pot furnace
固定式保温炉[熔炉](勺取)
basic electric furnace
碱性电炉
basic oxygen furnace
氧气顶吹转炉
batch furnace
分层式烘炉
bell hydrogen resistance furnace
钟罩式氢 气电阻炉
bell-type furnace
罩式炉
bending furnace
弯板炉(平板玻璃)
billet furnace
小钢坯加热炉
biscuit furnace
坯炉
blast cupola furnace
鼓风炉; 化铁炉
blast smelting furnace
鼓风熔炉
blende roasting furnace
闪锌矿锻烧炉
blister furnace
泡铜熔炼炉
block furnace
方形电炉
blooming furnace
炼铁炉
blowing-up furnace
铅锌矿烧结炉
bogie hearth furnace
活(车)底炉
bogie-type furnace
车底式炉
boiler furnace
(汽)锅炉
bomb furnace
封管炉
Booth brass furnace
布思黄铜电炉
box-type furnace
箱式炉
brick furnace
砖窑
brick kiln
砖窑
brimstone furnace
燃硫炉
cabinet-type electric furnace
箱式电炉
calcination furnace
锻烧炉; 烘焙炉; 灰化炉
cap cover furnace
罩式炉
capacitor firing furnace
电容器焙烧炉
car bottom furnace
活底炉子, 车底式炉
car hearth furnace
活底炉
car tunnel furnace
隧道式炉
carbide furnace
炭精电极炉, 碳化炉
carbon resistance furnace
碳阻电炉
carbon tube furnace
碳管炉
car-bottom batch-type furnace
车底式热处理炉
carburizing furnace
渗碳炉
catalan furnace
土法炼铁炉
catalyst furnace
催化(剂)炉; 接触炉
catenary reheating furnace
悬束式炉cathode-ray 阴极射线炉
cell furnace
(电加热的)玻璃池窑[炉]
cementating furnace
渗碳炉
chain-conveyer furnace
链式炉
chamber furnace
分室炉, 箱式炉
channel type induction
有芯(工频)感应炉
charcoal blast furnace
木炭高炉
charge-resistance furnace
电荷电阻炉
chemical recovery furnace
化学回收炉
chlorination furnace
氯化炉
circular furnace
环形炉
closed vessel furnace
密闭式炉
coil annealing furnace
带卷退火炉
coiler furnace
卷取炉
coke furnace
炼焦炉
coke-fired crucible furnace
焦炭坩埚炉
cold-mo(u)ld furnace
自耗电极真空电弧炉; 冷模炉
combustion tube furnace
燃烧管炉
commercial furnace
工厂炉子
compartment furnace
间格窑[炉]
conducting hearth furnace
炉底导电的炉子
consumable electro-arc furnace
(真空)自耗电弧炉
consumable electrode furnace
自耗(电极)炉
container-glass furnace
瓶罐玻璃熔窑
continuous passing furnace
直通式炉
continuous reheating furnace
连续式加热炉
continuous ribbon furnace
连续带式炉
continuous slab-heating furnace
板坯连续加热炉
continuous tunnel furnace
隧道炉
controlled atmosphere furnace
保护气体炉, 可控气氛炉
converting furnace
吹炼炉, 吹风氧化炉
convection-type furnace
间接加热的热处理炉(零件装在马弗罩内)
conveyer furnace
输送式加热炉
core drying furnace
型芯烘炉
core rack furnace
架式烘芯炉
core type induction furnace
铁芯式感应炉, 低频炉
coreless type induction furnace
无铁心感应炉(高频炉)
corrugated furnace
波纹管道
cover-type annealing furnace
罩式退火炉
cracking furnace
裂化炉; 裂解炉
cross-fired furnace
横焰炉
cross-fired glass melting furnace
横火焰池窑
crucible melting furnace
坩埚式炉
cryptol furnace
炭粒电阻炉
crystal growing furnace
晶体生长炉
cupel furnace
灰吹炉, 提银炉
cupellation furnace
灰吹炉, 提银炉
cupelling furnace
烤炉
cupola (blast) furnace
化铁(鼓风)炉
curtain type furnace
气幕式炉
cyclone furnace
气旋炉
cylinder epitaxial furnace
桶式外延炉
Czochralski crystal-pulling furnace
切克劳斯基拉晶炉
day tank furnace
日槽熔炉
decomposing furnace
分解炉 (Dickon 法中氯化氢的氧化炉)
descaling furnace
氧化皮清除炉
desulfurizing furnace
脱硫炉
Detroit rocking furnace
底特律?谑降缏?
die casting furnace
保温炉(配合压铸机用)
diffusion furnace
扩散炉
dipout furnace
双用熔炉(熔化及保温)
direct-fired coil furnace
直接加热的热处理炉
direct-melt furnace
直接拉丝池窑
distilling furnace
蒸馏炉
dore furnace
金银炉
double bed furnace
双膛炉
double hearth furnace
双膛炉
double upshot furnace
直立双膛
double-crown furnace
双拱窑炉
double -current furnace
双电流电炉
double-deck furnace
双层炉
double-end fired furnace
两 头烧火加热炉
double-muffle furnace
双层内罩[罩式]炉, (烟气上行)加热炉
down-draft furnace
倒风炉; 倒焰炉; 烟道气下行的加热炉
draught furnace
通风炉
drawing furnace
回火炉
drip furnace
液体燃料燃烧用炉
drum furnace
回转炉; 鼓形炉
drying furnace
干燥炉; 烘炉
dual chamber furnace
双室炉; 双膛炉
duo-muffle furnace
二层马弗炉[套炉]
Efco-Northrup furnace
高频感应炉
electric box furnace
箱式电炉
electric crucible furnace
电坩埚炉
electric induction furnace
感应(电)炉
electric melting furnace
电熔炉
electric meffle furnace
电马弗炉
electric rocking furnace
(间接)电?诙?? 单相电弧炉
electric shaft furnace
竖井式电炉
electric smelting furnace
电气熔炼炉
electric steel furnace
电炉钢炉
electric tilting furnace
倾注式电炉
electric tube furnace
管式电炉
electroflux refining furnace
电碴(精炼)炉
electron-beam furnace
(电子)轰击炉
electron-beam floating zone furnace
电子束浮区提纯炉
electron beam single crystal furnace
电子束单晶炉
electron beam zone refining furnace
电子束区域熔炼炉
enamel furnace
搪瓷窑
end-fired furnace
端焰窑, 马蹄焰窑
end-port furnace
马蹄焰窑(炉), U形焰窑.纵火焰(池)窑
epitaxial furnace
外延炉
equilibrium blast furnace
等风(冲天)炉
expansion furnace
前置炉膛
extended furnace
前置炉膛
extened launder furnace
带延伸流槽(的)熔炉
extract furnace
提取居热炉
fast extrusion furnace
快速压出炉
ferro-alloy furnace
铁合金炉
fiber drawing furnace
拉丝炉
fining furnace
精炼炉
fixed hearth furnace
固定床膛火炉
flame furnace
反射炉
flash roasting furnace
急骤锻烧炉
flat glass furnace
平板玻璃窑炉
floor firing furnace
炉底燃烧炉
flowing furnace
熔化炉
fluid-bed furnace
流动粒子炉
fluidized sand bed furnace
流化砂床炉
"fluosolid" furnace
沸腾(焙烧)炉
forced circulation furnace
强制循环的热处理炉
forced -draught furnace
压力通风炉
forging furnace
锻炉
founding furnace
熔炉
foundry furnace
铸造(熔化)炉
four hearth furnace
四膛炉; 四室炉
four stack diffusion furnace
四管扩散炉
free-hearth electric furnace
炉底导电直热式电弧炉
fritting furnace
烧结炉
Gaines locomotive furnace
更讷司机车火箱
gallery furnace
长廊炉
garbage furnace
垃圾焚烧炉
gas furnace
煤气炉
gas curtain furnace
(保护)气体帘幕热处理炉
gas-fired air furnace
煤气反射炉
gas-fired reverberatory furnace
煤气渗碳炉[反射炉]
glass tank furnace
玻璃池窑
glowing furnace
淬火炉
gradient furnace
梯度炉
granular carbon resistance furnace
碳粒电阻炉
grate furnace
炉排炉, 层燃 炉
grate-fired furnace
层燃炉膛
greaves Etchell furnace
大电极型弧阻式电炉
hair-pin furnace
搪烧(用)U形炉
hand reverberatory furnace
人工操作反射炉
hand-rabbled-raked furnace
人工炉
hardening furnace
硬化炉; 淬火炉
hearth furnace
平底炉; 高壁炉, 墙壁高炉; 膛式炉
heat treatment furnace
热处理炉; 热处理用电炉
heating furnace
加热炉
hermetic seal furnace
气密封炉
high bloomery furnace
高温炼铁炉
high-pressure crystal growth furnace
高压晶体生长炉
high-speed heating furnace
(分段)高温快速加热炉
high-temperature thermoelectric furnace
高温热电炉
holding furnace
混合炉, 保温炉
homogenizing furnace
均化炉
hood-type annealing furnace
罩式退火炉
horizontal diffusion furnace
卧式扩散炉
horizontal induction furnace
卧式感应加热炉
horizontal rotary furnace
卧式转炉
horizontal tube furnace
平管炉
horizontal vacuum resistance furnace
卧式真空电阻炉
horizontal-chamber furnace
卧式炉
horseshoe flame furnace
马蹄焰(池)窑
hot-air furnace
热空气炉
hot-wall tube furnace
热壁管式炉(通过管壁对管内加热)
hydrocarbon performer furnace
烃类转化炉; 烃类加工用炉
氢气电阻炉
image furnace
聚焦炉(产生高温的设备)
immersed electrode furnace
浸极式炉(一种液体渗碳炉)
improving furnace
精炼炉
in-and-out reheating furnace
分批加热炉
indirect arc rocking furnace
摇动式间接电弧炉
indirect fired furnace
间接加热的热处理炉
induction furnace
感应电炉
ingot furnace
热锭炉; 铸锭炉
industrial furnace
工业用电炉, 直接弧光式电炉
in-hearth-out-hearth furnace
旧砂(干法)再生炉
insulated furnace
热处理绝热炉
internal furnace
内炉膛
iron-melting furnace
熔铁炉
Kellogg millisecond furnace
凯洛格毫秒炉
kettle furnace
倾动式保温炉
krupp furnace
粒状碳电阻炉
laboratory electric furnace
实验室用电炉
large-bore furnace
大口径炉
lead smelting furnace
熔铅炉; 炼铅炉; 化铅炉
lead-pot furnace
铅浴炉
Lectromelt furnace
还原熔炼电弧炉
liftout crucible type furnace
坑式坩埚炉
line-frequency furnace
工频(感应电)炉
line-frequency coreless induction furnace
无芯工频感应电炉
liquation furnace
熔化炉
liquid-bath furnace
熔炉
live-bottom furnace
单电极(炉底通电)电弧熔炼炉
Loddby furnace Loddby
(镁盐回收)旋风炉
long bedded furnace
长底炉
longitudinal sloping hearth furnace
斜底式炉
low-blast furnace
低压鼓风炉, 低压高炉
low-shaft blast furnace
矮高炉
main frequency furnace
工频感应炉
main frequency coreless induction furnace
无芯工频感应电炉
maintaining furnace
保温炉
marble furnace
(玻璃)球窑, 拉丝炉(附有加入玻璃球装置的拉丝玻璃纤维的电炉)
Martin furnace
平炉, 马丁炉
matting furnace
锍熔炼炉
mechanical salt-cake furnace
机动盐饼炉
mechanically rabbled furnace
机械搅拌炉
mechanically raked furnace
机械搅拌炉
medium-frequency induction furnace
中频感应电炉
melting furnace
熔窑
merchant furnace
工厂熔炼炉
metallurgical furnace
冶金炉
mill furnace
加热炉
molybdenum wire furnace
钼丝炉
Morgan crucible furnace
摩尔根坩埚式电炉
muffle furnace
马弗炉, 套炉, 回热炉, 膛式炉, 隔焰炉
multi-flame pot furnace
多焰坩埚窑
multihearth furnace
(硫酸制造)多层炉
multiple bedded furnace
多层炉
multiple chamber furnace
多室式炉
multiple muffle furnace
多套炉
multiple stack annealing furnace
塔式连续退火炉
multiple-electrode furnace
多极电炉
multistage furnace
多段炉
multi-zone reheating furnace
多段式加热炉
native style blast furnace
土高炉
natural draft pit furnace
自然通风地坑炉
neutral salt-bath electric furnace
中性盐浴电炉
niter-cake furnace
硝饼炉
nitrate electric furnace
硝盐电炉
nitriding furnace
氮化炉, 渗氮炉
nitriding electric furnace
氮化电炉
non-ferrous melting furnace
有色金属熔炉
normalizing furnace
常化炉, 正火炉
notched furnace
锯条底炉
one-pot furnace
单坩埚窑
one-stor(e)y furnace
单层炉
open furnace
敞开炉
open coil annealing furnace
松卷退火炉
open flame furnace
有焰炉
open-arc furnace
明弧炉
open-hearth steel furnace
平炉
ore furnace
煅矿炉
Osmund furnace
高风箱炉, 奥斯猛炉
oven-type furnace
箱式炉
oxide-drossing furnace
氧化撇渣炉[造渣炉]
oxidizing furnace
氧化炉
pack-hardening furnace
装箱渗碳炉
parallel-arc furnace
并联电弧炉
parallel-flow heating furnace
顺流式连续加热炉
parting furnace
分离炉
patentizing furnace
铅淬火炉, 烧线炉
pebble furnace
卵石炉
periodic annealing furnace
间歇式退火炉
permeable-lining furnace
可透衬层炉
pernot furnace
反射搅炼炉
pilot furnace
试验窑炉
pit furnace
坑式炉
Pittsburgh tank furnace
匹兹堡(无槽引上)池窑
plate-glass furnace
平板玻璃池窑
plus-pressure furnace
加压炉
polymerization furnace
聚合炉
pool furnace
反射炉, 床炉
portable -furnace
移动式炉, 轻便型炉
portable cover furnace
罩式炉
pot furnace
罐炉
preheating furnace
预热炉
press pouring furnace
气压浇注炉
process furnace
化工过程加热炉
producer furnace
煤气发生炉
puddle furnace
搅炼炉
pulling furnace
拉晶炉
pyrite furnace
硫铁矿焙烧炉
pyrite hand-rabbled furnace
黄铁矿手工搅拌炉
pyrite shelf furnace
黄铁矿屉式炉
pyrolysis tube furnace
裂解管式炉
pyrolyzing furnace
热解炉
quenching furnace
淬火炉
rabbling furnace
搅拌炉
radiant resistance furnace
辐射电阻炉
radiant tube-fired cover-type furnace
辐射管加热的罩式(退火)炉
radiation resistance furnace
辐射电阻炉
raffinate furnace
残液加热炉
recirculation furnace
循环炉; (裂化装置中)循环气体的炉子
recuperative furnace
同流换热炉, 换热式燃烧器
recuperative pot furnace
换热式(玻璃)坩埚熔窑(炉)
recuperative tank furnace
换热式池窑
recuperator furnace
同流换热器炉
reducing furnace
还原炉
refinery furnace
精炼炉
reforming furnace
重整炉(增加汽油辛烷值的炉子)
refuse destructor furnace
废渣焚烧炉
regenerative furnace
蓄热式炉
resistance heated furnace
电阻加热炉
resistive hearth furnace
炉床电阻炉
retort furnace
甑式炉
reverberating furnace
返焰炉
反射炉
reversing furnace
换火式窑炉, 蓄热室式窑炉
revolving furnace
(回)转 炉
revolving black ash furnace
旋转黑灰炉
rf induction furnace
射频感应炉
ring-shaped induction furnace
环形感应电炉
rocker-bar furnace
摇杆推料炉, 步入式加热炉
rocking arc furnace
?谑降缁÷?
rocking brass furnace (for zinc refining)
?谑?炼锌)电炉
rocking chair induction furnace
可倾式感应炉
roll down furnace
斜底式炉, 滚式炉
roller hearth furnace
辊底式炉
roller hearth continuous rotaflame furnace
转焰炉
Ross-Wagner furnace R.W.
碱回收炉
rotary hearth furnace
转底炉, 环形炉
rotary tube furnace
旋转管式炉
salt-bath furnace
盐浴(退火)炉, 盐浴(退火)槽
salt-cake furnace
盐饼炉
scaling furnace
(铁皮)镀锡炉
sealed quench furnace
封闭式淬火炉
semi-direct furnace
半煤气窑
semi-muffle type furnace
半马弗式炉, 带高挡火墙式花墙炉子
series arc furnace
串电弧炉
shaft furnace
高炉, 井式炉, 竖炉
sheet furnace
?寮尤嚷?
sheet-glass tank furnace
平板玻璃池窑
short annealing furnace
快速退火炉
side-charged furnace
侧装料式炉
side-fired furnace
横焰炉(两侧加热的炉子)
side-port furnace
横焰炉
Siemens-Martin furnace
平炉, 马丁炉
Silesian furnace
蒸锌炉
singeing furnace
燎毛炉
single-cell furnace
单室炉
sintering furnace
烧结炉
skull furnace
(真空自耗)凝壳炉
skull melting furnace
渣壳熔炼炉, 熔渣炉
slit-port furnace
窄缝喷火口炉(空气, 煤气分别从坩埚炉底部窄缝进入炉中)
sloping roof furnace
斜顶炉
slot-port furnace
窄缝喷火口炉
slot-type furnace
缝式炉
small tank furnace
小型池窑
smothered arc furnace
顺电弧炉
Snyder induction furnace
斯奈德电感炉
soaking furnace
均热炉
soda recovery furnace
碱回收炉
softening furnace
槽沉炉(光学玻璃热加工用)
solar furnace
太阳能炉
Solvex cracking furnace
索维克斯裂化炉(有悬吊挡板的火焰自两边加热的裂化炉)
special atmosphere (annealing) furnace
保护气氛(退火)炉
speckled furnace
箱式炉
split flame furnace
分焰炉
Stassano furnace
旋转电弧炉
stationary pot furnace
固定式坩埚炉(有色压铸用)
Sterling furnace
斯特林炼锌电弧炉
Stetefeldt furnace
斯特费尔特焙烧炉
straight-draft furnace
直接通风炉
submerged-arc furnace
埋 弧炉
sugar furnace
糖灶
supercharged furnace
增压炉膛
sweat furnace
热析炉
tapping furnace
放液炉; 液流电炉
teeming furnace
铸造(电)炉
tempering furnace
回火炉
terrace furnace
梯台式炉
terrace wall type reforming furnace
阶梯式转化炉
thermal decomposition furnace
热(分)解炉
thermostatically controlled furnace
恒温调节炉
Thierry zinc furnace
塞利炼锌炉
three-cell furnace
三室炉
tile furnace
瓦窑
tilting crucible furnace
倾动式坩埚炉
tinning furnace
镀锡炉
top-flame furnace
上部加热的坩埚窑炉
toughening furnace
钢化炉
tower furnace
竖炉, 塔式炉
travelling furnace
移动炉, 活动炉
tube cracking furnace
管式裂解炉
tube electric furnace
管式电炉
tubular furnace
管式炉
tungsten coil furnace
钨丝炉
tunnel annealing furnace
隧道式退火炉
twin tank furnace
双池窑炉
two chamber vacuum furnace
双室真空炉
two zone tubular furnace
双区管式炉
tyre heating furnace
轮箍加热炉
underdraft furnace
下抽(风)炉
underfeed furnace
下加热式炉
unmuffled type furnace
无马弗炉
updraft furnace
直焰炉
uphill furnace
倾斜炉
upshot furnace
火焰上喷式加热炉
vacuum firing furnace
真空炉
vacuum sintering furnace
真空烧结炉
vapor pressure control furnace
汽压控制炉
vertical bell-type furnace
立式钟罩炉
vertical cylindrical furnace
圆形井式炉
vertical multi-stage furnace
立式多段燃烧炉
vertical shaft furnace
立式燃烧炉
viscosity breaking furnace
减粘裂化炉
walking beam (type) furnace
步进式炉
warm-air furnace
空气加热器, 热风炉
water jacket furnace
水套(鼓风)炉[冶炼炉]
water-cooled furnace
水冷炉膛
Wedge furnace
威吉炉; 拱床炉
welding furnace
烧结炉
wet bottom furnace
液态排渣炉膛
wire-mesh belt furnace
网带式炉
wire-wound furnace
电阻丝炉; 线绕电炉
working furnace
玻璃热加工炉
Wulff pyrolysis furnace
伍尔夫裂解炉
zinc distillation furnace
蒸锌炉
zirconia tube furnace
氧化锆管电炉
zone-fire two-zone continuous furnace
分段加热双段连续炉
签到天数: 542 天
发表于 2008-5-16 11:49:34 | 显示全部楼层
一箭双雕!既学设备,有看一点英语。谢谢楼主
GMT+8, 2026-7-21 03:54 , Processed in 0.029122 second(s), 21 queries .
