查看: 4825|回复: 1
[求助] 谁能看懂这个计算铁素体的体积分数的VB程序
发表于 2008-6-6 17:03:15 | 显示全部楼层 |阅读模式
Option Explicit
Dim ca(1000), cacm(1000), wf(1000), xfc(1000), xpc(1000), temp(1000), tempp(1000), delt As Double
Dim xf(1000), xaf(1000), xff(1000), tf(1000), bf(1000), nf As Double
Dim xp(1000), xpp(1000), tp(1000), bp(1000), np As Double
Dim c, mn, pf, pp As Double
Dim i, j As Integer
Dim wf1(1000), wf2(1000) As Double
Dim wp1(1000), wp2(1000) As Double
Dim xfc1(1000), xfc2(1000), tf1(1000) As Double
Dim xpc1(1000), xpc2(1000), tp1(1000) As Double
Dim cool, coolp As Double
Dim k, l As Integer
Dim deltxf(1000), sumf(1000)  As Double
Dim deltxp(1000), sump(1000)  As Double
Dim pf1, pf2(1000), pf3, pf4, dr0, dr, ae3, strain As Double
Dim pp1, pp2(1000), pp3, pp4, ae1 As Double
Dim pwf(1000) As Double
Dim pwp(1000) As Double
Dim cau(1000) As Double
Dim tpe As Double
Dim temperature As Double
Dim tem As Double
Dim delt1 As Double
Private Sub cmdSave_Click()
Dim lp As Integer
    Open "F:\毕业设计\Phase Fraction Program\result.txt" For Output Access Write As #100
    Print #100, "Step" & vbTab & vbTab & "Xf" & vbTab & vbTab & "Temp" & vbCrLf
    For lp = 1 To i - 1
        Print #100, lp & vbTab & vbTab & xf(lp) & vbTab & vbTab & temp(lp) & vbCrLf
    '    Write #100, vbCrLf
    Next lp
    Print #100, vbCrLf
    Print #100, vbCrLf
    Print #100, "Step" & vbTab & vbTab & "Xp" & vbTab & vbTab & "Tempp" & vbCrLf
    For lp = 1 To k - 1
        Print #100, lp & vbTab & vbTab & xp(lp) & vbTab & vbTab & tempp(lp) & vbCrLf
    Next lp
    Close #100
End Sub
Private Sub Command1_Click()
c = 0.12  '0.07   0.36
mn = 0.5 ''0-1.3
pf = 7.86
pp = 7.81
nf = 0.89
np = 0.99
delt = 1
tf(0) = 0
tp(0) = 0
cool = 15 ''''''(884 - 600) / 25 ''''11.36 ''''1-17.9
sumf(0) = 0
sump(0) = 0
strain = 0.06 ''0
dr0 = 15 '''''3.5-23
pf3 = 67
pf4 = 1.9
dr = dr0 / (1 + 0.5 * strain)
pf1 = 2 / (dr * (c + (mn / 6)))
pp1 = 13 / dr
pp3 = 47
pp4 = 2.2
pf2(0) = 0
pp2(0) = 0
delt1 = 10 ^ (-3)
ae1 = 727
coolp = 5
ae3 = 904.7899 - 374.25945 * c + 195.43806 * c * c
tpe = 682.71 - 156.07 * c - 6.6809 * mn - 9 * (cool ^ 0.12) '''
'''Calculation of ferrite fraction
For i = 1 To 100
   '''' pf2(i) = ae3 - 215 + (28.15 / (dr ^ 0.02)) - 0.0007 * c
    temperature = 874.087 + 407.67788 * c - 3724.46472 * c * c + 8293.05941 * c * c * c - 6277.1172 * c * c * c * c - 22.56 * (cool ^ 0.27)
    temp(i) = temperature - (i - 1) * cool * delt
    tem = temp(i - 1)
    j = i
   ''''' pwf(i) = Abs((temp(i) - pf2(i - 1)) / pf3) ^ pf4   '''''''''''
    pwf(i) = ((temp(i) - pf2(i - 1)) / pf3) ^ pf4
    bf(i) = pf1 * Exp(-pwf(i))
    xf(i) = 1 - Exp((-bf(i)) * ((delt + tf(i - 1)) ^ nf))
    cacm(i) = -0.29729 + (4.57757 / 10000) * temp(i) + (1.37432 / 1000000) * temp(i) * temp(i)
    cau(i) = (c - xf(i) * ca(i)) / (1 - xf(i))
    If cacm(i) < cau(i) Then
       Exit For
    End If
    ca(i) = 0.04628 + (1.27515 / 100000) * temp(i) - (1.695367 / 100000000) * temp(i) * temp(i)
    wf1(i) = cacm(i) - c
    wf2(i) = cacm(i) - ca(i)
    wf(i) = wf1(i) / wf2(i)
    xfc1(i) = wf(i) / pf
    xfc2(i) = (1 - wf(i)) / pp
    xfc(i) = xfc1(i) / (xfc1(i) + xfc2(i))
    temp(i + 1) = temperature - ((i + 1) - 1) * cool * delt
    '''pwf(i + 1) = Abs((temp(i + 1) - pf2(i)) / pf3) ^ pf4  ''''''''
     pwf(i + 1) = ((temp(i + 1) - pf2(i)) / pf3) ^ pf4
    bf(i + 1) = pf1 * Exp(-pwf(i + 1))
    ca(i + 1) = 0.04628 + (1.27515 / 100000) * temp(i + 1) - (1.695367 / 100000000) * temp(i + 1) * temp(i + 1)
    cacm(i + 1) = -0.29729 + (4.57757 / 10000) * temp(i + 1) + (1.37432 / 1000000) * temp(i + 1) * temp(i + 1)
    wf1(i + 1) = cacm(i + 1) - c
    wf2(i + 1) = cacm(i + 1) - ca(i + 1)
    wf(i + 1) = wf1(i + 1) / wf2(i + 1)
    xfc1(i + 1) = wf(i + 1) / pf
    xfc2(i + 1) = (1 - wf(i + 1)) / pp
    xfc(i + 1) = xfc1(i + 1) / (xfc1(i + 1) + xfc2(i + 1))
    xff(i) = (xfc(i) / xfc(i + 1)) * xf(i)
    tf1(i) = Log(1 / (1 - xff(i)))
    tf(i) = ((tf1(i)) / bf(i + 1)) ^ (1 / nf)
    deltxf(i) = xf(i) - xf(i - 1)
    sumf(i) = deltxf(i) + sumf(i - 1)
Next i
   Text1.Text = Str(j)
   Text2.Text = Str(sumf(i - 1))
   Text3.Text = Str(tem)
  '''Calculation of pearlite fraction
  For k = 1 To 100
    pp2(k) = ae1 - 175 + (27.8 / (dr ^ 0.02)) - 22 * c
    If Abs(cool - coolp) < 4.5 Then
       cool = coolp - (cool - coolp) / 4.5
    End If
    tempp(k) = tem - (k - 1) * cool * delt
    l = k
    pwp(k) = ((tempp(k) - pp2(k - 1)) / pp3) ^ pp4 ''''''''''''
    bp(k) = pp1 * Exp(-pwp(k))
    xp(k) = 1 - Exp((-bp(k)) * ((delt + tp(k - 1)) ^ np))
    If tempp(k) < tpe Then
    Exit For
    End If
    ca(k) = 0.04628 + (1.27515 / 100000) * temp(k) - (1.695367 / 100000000) * temp(k) * temp(k)
    cacm(k) = -0.29729 + (4.57757 / 10000) * temp(k) + (1.37432 / 1000000) * temp(k) * temp(k)
    wp1(k) = cacm(k) - c
    wp2(k) = cacm(k) - ca(k)
    pwp(k) = wp1(k) / wp2(k)
    xpc1(k) = pwp(k) / pf
    xpc2(k) = (1 - pwp(k)) / pp
    xpc(k) = xpc1(k) / (xpc1(k) + xpc2(k))
    tempp(k + 1) = tem - ((k + 1) - 1) * cool * delt
    pwp(k + 1) = ((tempp(k + 1) - pp2(k)) / pp3) ^ pp4 '''''''''''''''
    bp(k + 1) = pp1 * Exp(-pwp(k + 1))
    ca(k + 1) = 0.04628 + (1.27515 / 100000) * temp(k + 1) - (1.695367 / 100000000) * temp(k + 1) * temp(k + 1)
    wp1(k + 1) = cacm(k + 1) - c
    wp2(k + 1) = cacm(k + 1) - ca(k + 1)
    pwp(k + 1) = wp1(k + 1) / wp2(k + 1)
    xpc1(k + 1) = pwp(k + 1) / pf
    xpc2(k + 1) = (1 - pwp(k + 1)) / pp
    xpc(k + 1) = xpc1(k + 1) / (xpc1(k + 1) + xpc2(k + 1))
    xpp(k) = ((1 - xpc(k)) / (1 - xpc(k + 1))) * xp(k)
    tp1(k) = Log(1 / (1 - (xpp(k))))
    tp(k) = ((tp1(k)) / bp(k + 1)) ^ (1 / np)
    deltxp(k) = xp(k) - xp(k - 1)
    sump(k) = deltxp(k) + sump(k - 1)
  Next k
    Text4.Text = Str(l)
    Text5.Text = Str(sump(k - 1))
    Text6.Text = Str(tempp(l))
    Text7.Text = Str(1 - sumf(j - 1) - sump(l - 1))
End Sub
Private Sub Command2_Click()
End
End Sub
以上就是程序
急切盼望哪位高手能看出程序中用的所有公式!!!!
若有高手请联系QQ:258145361
wangqinghua196 + 5 感谢上传!
发表于 2008-6-12 11:38:39 | 显示全部楼层
123
这个你到vb的论坛中去发一下,那里懂的人多一点。
GMT+8, 2026-7-17 10:46 , Processed in 0.028181 second(s), 23 queries .
