查看: 5634|回复: 0
《Metallic Materials Physical, Mechanical, and Corrosion Properties》英文版.2003
发表于 2008-6-19 10:45:32 | 显示全部楼层 |阅读模式
书名:Metallic Materials: Physical, Mechanical, and Corrosion Properties
作者:P.E., Philip A. Schweitze
语言: English
出版社: CRC
出版日期: 2003-01-07
页码: 712
文档格式: PDF
ISBN: 978-0-8247-0878-8 (hardback) 978-0-203-91242-3 (electronic)
简介:
Metallic Materials compares and contrasts the corrosion resistance of wrought stainless steel and high nickel alloys and explores recent advances in the production of exotic metals. It emphasizes the physical and mechanical properties, corrosion resistance, workability and cost of various metals. The author analyzes the physical and mechanical properties of metals, defines relevant terminology, describes the various forms of corrosion to which metals may be susceptible, examines wrought ferrous metals, alloys, and typical applications, and covers wrought nickel and high nickel alloys. This is a handy reference for the busy engineer and student in corrosion, materials, chemical, mechanical, civil, design, process, metallurgical, manufacturing, and industrial engineering.
参与人数 1热处理币 +45 收起 理由
stigershu + 45 热处理资料销售额转账,本次附件销售故障一次 ...
GMT+8, 2026-7-18 11:22 , Processed in 0.027937 second(s), 24 queries .
