查看: 6351|回复: 0
通用电气招聘
发表于 2008-8-4 15:51:01 | 显示全部楼层 |阅读模式
通用电气的油气集团招聘-热处理方面的工程师:
Primary Responsibilities:
The Material & Processes Engineering Team is part of the Advance Technology Organization supporting Engineering, Sourcing and Global Service from the point of view of material selection/properties, failure, lifting.
In this team the Materials & Processes Expert is responsible for:
?        He is a resource for all Engineering personnel as an expert related to the chemical and mechanical properties for all manufacturing processes and especially special processes.
?        He is able to indicate equivalent materials to EU or USA standards and he is in charge to write the relevant technical documentation.
?        He works closely with the Engineering NPI team as it relates to material properties.
?        He is able to define and lead characterization activities for O&G product materials
?        He is able to find and propose new materials for O&G products
?        He works on filling database for material properties used for O&G product
        Qualifications Required:
?        Minimum 5yrs background in Material Properties and Special Processes
?        Knowledge of the material properties and metallurgy
?        Knowledge of heat treatment process
?        Ability to work and develop new approaches and technology to solve issues
?        Knowledge of design fundamentals to be applied to the selection of the material
欢迎投递简历:v420022@vastsea.com
GMT+8, 2026-7-19 01:32 , Processed in 0.026944 second(s), 22 queries .
