查看: 6939|回复: 2
[求助] 烦请有专家帮忙翻译一段英文,谢谢
签到天数: 52 天
发表于 2017-3-28 21:53:58 | 显示全部楼层 |阅读模式
When more than one gear is integral with a shaft, the primary heat treatment goal shall be to meet the case depth requirements in the one with the greatest half whole depth tooth thickness, unless otherwise
specified on the drawing.
其中 the one with the greatest half whole depth tooth thickness这个是怎么理解?
签到天数: 409 天
发表于 2017-4-11 10:41:34 | 显示全部楼层
硬化层满足最大齿厚一半厚度的深度
签到天数: 10 天
发表于 2017-11-16 22:10:31 | 显示全部楼层
深层深度至少达到齿厚的一半
GMT+8, 2026-7-19 07:48 , Processed in 0.027379 second(s), 21 queries .
