查看: 5776|回复: 0
工艺布局中的减排措施和废水回用
签到天数: 2802 天
发表于 2008-10-16 12:18:19 | 显示全部楼层 |阅读模式
工艺布局中的减排措施和废水回用
周鼎华
(无锡法福表面处理技术有限公司,江苏 无锡 214145)
摘 要:QPQ工艺产生的废水为碱性,铝合金阳极氧化工艺产生的废水是酸性。在工艺布局中将两者结合,可以使废水酸碱中和达到减少排放的效果。采用中和、混凝、沉淀和斜管分离的工艺流程,对废水进行深度处理后大部分回用于生产。
关键词:减排;废水回用
中图分类:X131.2;TG174.451 文献表识码:B 文章编号:1673-4971(2009)02-0064-03
Measures of Reduction in Pollutant Discharge and Techniques of Recycling Waste Water in Technology Design
ZHOU Ding-hua
(Wuxi Fafu Techniques Surfaces Treatment Co., Ltd, Wuxi, Jiangsu 214145, P.R. China)
Abstract: The waste water produced by the QPQ technology is alkaline, while the waste water produced by the anodizing technology of the aluminum alloy is acid. In the technology design, if we combine to process the waste water produced by the aforementioned two technologies, the acid and alkali in the waste water will be neutralized in order to achieve the effect of reducing the pollutant discharge. Under the technology process of neutralization, coagulation and oblique pipe isolation, most of the waste water can be used for production after deep recycling.
Key words:
Reduction in pollutant discharge; Recycling waste water
刊登于《热处理技术与装备》2009年第2期
[ 本帖最后由 dhzhou888 于 2009-6-18 12:43 编辑 ]
参与人数 1热处理币 +6 收起 理由
stigershu + 6 感谢上传!
GMT+8, 2026-7-20 05:00 , Processed in 0.028775 second(s), 23 queries .
