查看: 31498|回复: 2
[Help] Help to translate
签到天数: 96 天
发表于 2018-12-27 08:18:18 | 显示全部楼层 |阅读模式
Who can help to translate the following requirements which is from AMS 2750E?
Thanks very much.
3.5.18 Relocation of Hot or Cold Recording Sensors for Class A or C Instrumentation
When the hottest and coldest temperature locations change within the furnace (based on the final readings from the most
recent Temperature Uniformity Survey), the recording sensor locations for types A and C instrumentation may need to be
moved within the furnace to reflect the new hottest and coldest locations within the work zone. These sensors do not
require relocation if the overall temperature uniformity does not exceed one half of the maximum temperature uniformity
tolerance for the applicable furnace class at all temperatures surveyed, or if the difference between the measured
temperature at the current recording locations and the actual respective hottest and coldest measured areas is less than
the system accuracy test (SAT) tolerance for the applicable furnace class.
发表于 2020-1-17 15:36:43 | 显示全部楼层
3.5.18重新安置用于A类或C类仪表的热或冷记录传感器
当炉内最高温和最低温的位置发生变化时(根据最低温的最终读数)
最近的温度均匀性调查),A型和C型仪器的记录传感器位置可能需要
在炉内移动,以反映新的最热和最冷的位置在工作区内。这些传感器不会
如果整体温度均匀性不超过最高温度均匀性的一半,则需要重新定位
适用炉类在所有调查温度下的公差,或测量值之间的差异
温度在当前记录的位置和实际分别测得的最热和最冷的区域小于
适用炉类的系统精度测试(SAT)公差。
参与人数 1热处理币 +40 收起 理由
cjzhou + 40 感谢参与!
签到天数: 96 天
 楼主| 发表于 2020-7-16 15:58:35 | 显示全部楼层
当炉内最高温和最低温的位置发生变化时(根据最低温的 ...
Dear Nbxbmy, Thanks very much!
Now we have the new version for AMS 2750 which is F.
It discribed much more clear for this reuqirements.
3.5.15 Relocation of Hot or Cold Recording Sensors for Type A and C Instrumentation
3.5.15.1 When the hot and cold temperature locations change within the furnace based on the readings from the most
recent TUS, the hot and cold recording sensors may need to be relocated to reflect the new hot and cold locations
within each qualified work zone.
3.5.15.2 The hot and cold recording sensors do not require relocation if either of the following conditions is met:
3.5.15.2.1 The temperature uniformity results do not exceed one half of the maximum temperature uniformity tolerance
for the applicable furnace class at all temperatures surveyed. The intent of this requirement is that the TUS
results do not exceed 1/2 of the uniformity tolerance in either direction from the set point temperature.
3.5.15.2.2 The difference between the measured temperature at the current hot and cold recording sensor locations and
the actual respective hottest and coldest measured locations is less than the maximum SAT difference for the
applicable furnace class (see Tables 14 and 15). The intent of this requirement is that the maximum and
minimum TUS sensor readings during the 30 minute TUS soak, recorded and corrected by the TUS recorder,
are compared to the furnace recording of the current hot and cold recording sensors at the same time, and
must not exceed the applicable SAT tolerance.
3.5.15.3 If the qualified operating temperature range exceeds 300 °F or 165 °C and the hot and/or cold recording sensors
are permanently positioned/fixed and need to be relocated, additional TUS temperatures shall be performed to
verify that the new locations are correct throughout the qualified operating temperature range of the furnace.
3.5.15.4 If the hot and/or cold recording sensors are not permanently positioned/fixed, they can be relocated without the
above testing if there is a diagram of the required location where the hot and cold recording sensors will be placed
at each process temperature.
GMT+8, 2026-6-28 16:14 , Processed in 0.028290 second(s), 23 queries .
