查看: 31934|回复: 5
[Help] AMS 2750F-Qualified operating temperature range
签到天数: 96 天
发表于 2020-7-16 16:28:52 | 显示全部楼层 |阅读模式
What's your explanation for the following item?
Let's take an exmaple to clarify if we are on the same page.
One Aging furnace, the norminal setting point temperature is 100℃ - 200℃. The temperature uniformity has been tested which is comply the tolerance is +/-3℃.
Then my question is the qualified temperature range is 100℃ - 200℃ or 97℃ - 203℃?
Thanks very much.
2.2.47 QUALIFIED OPERATING TEMPERATURE RANGE
The nominal set point temperature range of thermal processing equipment where temperature uniformity has been tested
within a qualified work zone and found to be compliant with required tolerances. The qualified operating temperature range
represents the temperature range including ± min/max uniformity tolerances within which parts or raw material can be
processed.
签到天数: 1637 天
发表于 2020-7-25 08:54:31 | 显示全部楼层
(100-200)±3℃   ~~~~~~~~~~~~~~~~
发表于 2020-8-5 09:46:59 | 显示全部楼层
The qualified temperature  rang is 100~200℃
签到天数: 96 天
 楼主| 发表于 2021-4-1 13:25:06 | 显示全部楼层
Thanks very much.
Couldn't agree with you more
签到天数: 96 天
 楼主| 发表于 2021-4-1 13:26:19 | 显示全部楼层
Now I think the qualified temperature range is 100℃-200℃ and the tempereture uniformity is +/-3℃.
Right?
GMT+8, 2026-7-16 20:30 , Processed in 0.030030 second(s), 21 queries .
