查看: 26757|回复: 3
[Discussion] AMS 2750F About calibration accuracy of sensor
发表于 2021-3-8 16:09:47 | 显示全部楼层 |阅读模式
Hello everybody, i have a question  about calibration accuracy of sensor as below,
According to AMS 2750F table 1,if the calibration accuracy of the type S control sensor is exceed the ±0.6℃ or±0.1%,
shall we scrap the sensor or continue to use the sensor with correction factors?
Hope your answer!
发表于 2021-4-9 13:14:18 来自手机 | 显示全部楼层
You shall use the sensor with correction factor. see table1 note(9).
签到天数: 96 天
发表于 2021-4-15 09:32:02 | 显示全部楼层
In my opinion, we have to scrap these sensors becuase they can't mee the requirements.
For table 1 Note 9
I think it is only suitable for sensors type not listed in Table 1 and used above 1316℃ then we can follow up the rules of Note 9.
签到天数: 21 天
发表于 2021-6-21 11:19:43 来自手机 | 显示全部楼层
See table1 note(9).....
GMT+8, 2026-6-28 16:14 , Processed in 0.028282 second(s), 22 queries .
