查看: 6558|回复: 0
Heat Treatment, Selection, and Application of Tool Steels.2nd Edition.2009
签到天数: 2946 天
发表于 2021-10-21 08:03:21 | 显示全部楼层 |阅读模式
Heat Treatment, Selection, and Application of Tool Steels 2nd Edition
作者:William E. Bryson
2009年出版
《工具钢的热处理、选择和应用》第2版
目录:
Introduction.................................................................................... v
Preface............................................................................................ ix
Chapter 1 What Is Steel?.............................................................1
Chapter 2 Exactly What Is Heat Treatment Doing?.....................5
Chapter 3 The Basic Furnace Room Tools ..................................9
Chapter 4 Surface Protection ....................................................21
Chapter 5 The Recipe for Heat Treating D2 Tool Steel.............29
Chapter 6 Heat Treating A2 Tool Steel .....................................49
Chapter 7 Heat Treating A6 Tool Steel .....................................57
Chapter 8 Heat Treating H13 Tool Steel ..................................63
Chapter 9 Heat Treating S7 Tool Steel......................................69
Chapter 10 Heat Treating M2 High Speed Tool Steel.................75
Chapter 11 Heat Treating AISI 4140 Medium Alloy Steel...........83
Chapter 12 Heat Treating O1 Tool Steel ....................................89
Chapter 13 Heat Treating W1 Tool Steel ....................................93
Chapter 14 Heat Treating CPM 10V.......................................99
Chapter 15 Cryogenics .............................................................107
Chapter 16 Guidelines for Grinding Hardened Tool Steel .........115
Chapter 17 Good Design Practices............................................121
Chapter 18 Welding Tool Steels ................................................127
Chapter 19 The Effects of EDM ...............................................131
Chapter 20 Tool Steel Selection ................................................135
Chapter 21 Helpful Hints and Tidbits.......................................165
Glossary.......................................................................................209
Index...........................................................................................237
GMT+8, 2026-7-18 21:52 , Processed in 0.030184 second(s), 26 queries .
