查看: 6130|回复: 0
Steel Heat Treatment:Equipment and Process Design.2007
签到天数: 2946 天
发表于 2021-10-22 07:35:05 | 显示全部楼层 |阅读模式
钢的热处理手册 第2版 《钢的热处理:设备和工艺设计》
Steel Heat Treatment Handbook Second Edition
作者:George E. Totten,Ph.D.,FASM
出版:Talor & Francis
目录:
SECTION I: Equipment
Chapter 1 Heat Treatment Equipment ................................................................................3
George E. Totten, N. Gopinath, and David Pye
Chapter 2 Design of Steel-Intensive Quench Processes ...................................................193
Nikolai I. Kobasko, Wytal S. Morhuniuk, and Boris K. Ushakov
Chapter 3 Vacuum Heat Processing.................................................................................239
Bernd. Edenhofer, Jan W. Bouwman, and Daniel H. Herring
Chapter 4 Induction Heat Treatment: Basic Principles,
Computation, Coil Construction, and Design Considerations........................277
Valery I. Rudnev, Raymond L. Cook, Don L. Loveless,
and Micah R. Black
Chapter 5 Induction Heat Treatment: Modern Power Supplies,
Load Matching, Process Control, and Monitoring.........................................395
Don L. Loveless, Raymond L. Cook, and Valery I. Rudnev
Chapter 6 Laser Surface Hardening.................................................................................435
Janez Grum
SECTION II: Testing
Chapter 7 Metallurgical Property Testing........................................................................569
Xiwen Xie
Chapter 8 Mechanical Property Testing Methods ...........................................................641
D. Scott MacKenzie
Index...................................................................................................................................697
本书和teel Heat Treatment: Metallurgy and Technologies是一套书中的上下卷
http://www.rclbbs.com/forum.php?mod=viewthread&tid=301514
(出处: 热处理论坛)
GMT+8, 2026-7-19 07:25 , Processed in 0.029757 second(s), 26 queries .
