查看: 6213|回复: 1
[书籍] 《Solid State Transformation And Heat Treatment》Alain Hazotte.2005
签到天数: 2926 天
发表于 2022-6-3 15:32:09 | 显示全部楼层 |阅读模式
固态转变和热处理
The final microstructures of engineering materials are very often obtained through solid state
transformation process(es). A good knowledge of the basic transformation mechanisms, associated with a tight control of the relevant process parameters, are vital to optimise the material
properties. Thus, one symposium of Euromat 2003, the 8th European Congress and Exhibition
on Advanced Materials and Processes held in Lausanne (CH) on 1-5 september 2003, was logically devoted to “Solid State Transformations and Heat Treatments”. This symposium was open
to experimental and/or modelling works increasing this knowledge or/and explicitly making use
of it for process/property optimisation. About sixty oral and poster contributions were given.
Both diffusion-controlled and diffusionless transformations were concerned, covering a large
range of metallic or non metallic materials. The sessions gave rise to rich and animated debates
and drew the major directions of future development, specially in the field of transformation
modelling.
签到天数: 252 天
发表于 2022-7-1 08:41:56 | 显示全部楼层
多看看国外文献长长见识,就是外文的看着累人,几个月能看完就不错了:lol
GMT+8, 2026-6-28 20:14 , Processed in 0.027839 second(s), 22 queries .
