查看: 5427|回复: 0
[分享] Delta-tone表面处理方式
发表于 2009-1-20 19:10:39 | 显示全部楼层 |阅读模式
阴极保护作用cathodic protection for all kinds of parts ( fasteners >M6 )•优异的防腐性能•excellent prevention of ground-metal corrosion ( red rust ) bysacrificial galvanic corrosion protectionbarrier-effect of overlapping zinc –and aluminumflakesself healing-effect ( migration of zinc-corrosion-products )•好的耐热性good heat-resistance •耐化学性能好good resistance against oil, gasoline, organic-solvents, brake-fluid
GMT+8, 2026-7-17 08:28 , Processed in 0.027576 second(s), 23 queries .
