楼主: greatmanzhang
[Discussion] why don't we discuss with english?
发表于 2011-3-20 22:52:21 | 显示全部楼层
nodular cast iron 球墨铸铁
ductile cast iron 球墨铸铁
bronze 青铜
brass 黄铜
copper 合金
stainless steel不锈钢
decarburization 脱碳
scale 氧化皮
anneal 退火
process anneal 进行退火
quenching 淬火
normalizing 正火
Charpy impact text 夏比冲击试验
fatigue 疲劳
tensile testing 拉伸试验
solution 固溶处理
aging 时效处理
Vickers hardness维氏硬度
Rockwell hardness 洛氏硬度
Brinell hardness 布氏硬度
hardness tester硬度计
descale 除污,除氧化皮等
ferrite 铁素体
austenite 奥氏体
martensite马氏体
cementite 渗碳体
iron carbide 渗碳体
solid solution 固溶体
sorbite 索氏体
bainite 贝氏体
pearlite 珠光体
nodular fine pearlite/ troostite屈氏体
black oxide coating 发黑
grain 晶粒
chromium 铬
cadmium 镉
tungsten 钨
molybdenum 钼
manganese 锰
vanadium 钒
molybdenum 钼
silicon 硅
sulfer/sulphur 硫
phosphor/ phosphorus 磷
nitrided 氮化的
case hardening 表面硬化,表面淬硬
air cooling 空冷
furnace cooling 炉冷
oil cooling 油冷
el(转载自第一范文网http://www.diyifanwen.com,请保留此标记。)ectrocladding /plating 电镀
brittleness 脆性
strength 强度
rigidity 刚性,刚度
creep 蠕变
deflection 挠度
elongation 延伸率
yield strength 屈服强度
elastoplasticity 弹塑性
metallographic structure 金相组织
metallographic test 金相试验
carbon content 含碳量
induction hardening 感应淬火
impedance matching 感应淬火
hardening and tempering 调质
crack 裂纹
shrinkage 缩孔,疏松
forging 锻(件)
casting 铸(件)
rolling 轧(件)
drawing 拉(件)
shot blasting 喷丸(处理)
grit blasting 喷钢砂(处理)
sand blasting 喷砂(处理)
carburizing 渗碳
nitriding 渗氮
ageing/aging 时效
grain size 晶粒度
pore 气孔
sonim 夹砂
cinder inclusion 夹渣
lattice晶格
abrasion/abrasive/rub/wear/wearing resistance (property) 耐磨性
spectrum analysis光谱分析
heat/thermal treatment 热处理
inclusion 夹杂物
segregation 偏析
picking 酸洗,酸浸
residual stress 残余应力
remaining stress 残余应力
relaxation of residual stress 消除残余应力
stress relief 应力释放
I  just  want to say somefhing useful for you.Here are some  heattreatment vocabularies.
发表于 2011-3-24 12:27:08 | 显示全部楼层
who is the master of english in the forum
发表于 2011-3-24 12:30:32 | 显示全部楼层
i am just learning english by reading books writen by english
发表于 2011-3-31 15:49:43 | 显示全部楼层
i support  you,, foreign technology is advanced than chinese...so we should handle english language to development myself capability,
发表于 2011-4-28 16:47:07 | 显示全部楼层
let us start
发表于 2011-5-11 18:59:59 | 显示全部楼层
let's study english everyday,I think that oneday My english is very good.
GMT+8, 2026-6-28 17:18 , Processed in 0.027697 second(s), 18 queries .
