查看: 11249|回复: 15
[Help] How to control the cooling rate?
发表于 2009-4-8 11:30:05 | 显示全部楼层 |阅读模式
There is a thecnics "DISTENSIONE--STRESS RELIEVING"
1)        HEATING RATE LESS THAN 200℃/h
2)        FURNACE TEMPERATURE 630 TO 650℃
3)        TIME SOAKING: 1h
4)        COOLING RATE DOWN TO 300℃: 150℃/h
5)        COOLING FROM 300℃ IN STILL  AIR.
发表于 2009-4-8 11:43:59 | 显示全部楼层
You can use the instrument to control, manual control can also be used.
签到天数: 2926 天
发表于 2009-4-8 12:02:16 | 显示全部楼层
What type of furnace,please?
Air-cooled?Can be frequency?
 楼主| 发表于 2009-4-8 12:15:23 | 显示全部楼层
But the cruciai question is that---the furnace temperature is reduced so slowly,we can open the  furnace door ,but the furnace temperature changes so fast  that  we can not control it.
Oh,my broken English
 楼主| 发表于 2009-4-8 12:18:27 | 显示全部楼层
回复 3# stove 的帖子
It is car type furnace,and furnace cooling.
签到天数: 77 天
发表于 2009-4-8 12:26:31 | 显示全部楼层
you can set the few segments to control the cooling rate from the 650C to 300C,
for example 650C  0.5h;600C 0.5h;550C 0.5h etc
发表于 2009-4-8 12:35:05 | 显示全部楼层
sometimes we can get much faster cooling rate using the furnace fan without opening the door.
签到天数: 2926 天
发表于 2009-4-8 12:46:44 | 显示全部楼层
If you use the burner,May be able to pass into the air from the burner
If you use the above method,use a programmable temperature controller.
发表于 2009-4-8 16:25:26 | 显示全部楼层
You can use other cooling medium through the furnace,it can take away heat .control the cooling medium flow rate.we can control the furnace cooling rate.
发表于 2009-4-8 17:01:17 | 显示全部楼层
if the furnace have not the cooling system, that will be hard to control it, in my opinion, you can add some the an air cooling equipment, control the cooling rate by control the air speed.
 楼主| 发表于 2009-4-8 17:11:41 | 显示全部楼层
回复9#hongqk and 10# greatmanzhang 的帖子
It is a good idea,but needs to remould the furnace
签到天数: 332 天
发表于 2009-4-8 17:23:39 | 显示全部楼层
reply to WJFU66
it is difficult to assure the cooling speed on your equipment .
i agree to remould the furnace, add a PLC and air  pump to control the cooling and heating rate .
发表于 2009-4-11 18:36:00 | 显示全部楼层
回复 4# WJFU66 的帖子
this means you have a good furnace with less energy loss.
do you think it's help if you choose an old worn equipment or reduce your loading?
 楼主| 发表于 2009-4-11 21:05:51 | 显示全部楼层
回复 13# tong 的帖子
Thanks,but  I think it is impossible,furnace cooling rate is slow yet.
发表于 2009-4-13 11:14:42 | 显示全部楼层
it's up to you chose what to cooling it,generally, at start youcan use of cooling air,when it reach 400 degree,cooling it with water,then the cooling rate is faster than norm.
签到天数: 6 天
发表于 2009-5-12 22:21:46 | 显示全部楼层
150C/h from high temperature to 300,and according to the tyre of furnace ,I think cooling with the furnace while oopening the door !the cooling rate maybe middle of A and N.
just my own opinion ,maybe right maybe wrong !
GMT+8, 2026-6-28 20:11 , Processed in 0.033818 second(s), 21 queries .
