查看: 10254|回复: 6
[Help] "hardening and tempering steel "and"hardened and tempered steel&q
发表于 2009-4-11 10:18:01 | 显示全部楼层 |阅读模式
"hardening and tempering steel"及"hardened and tempered steel"
我在技术文件中见到这两个词,不知有什么区别?翻译成调质钢还是淬火和回火钢?希望高手不吝赐教!
发表于 2009-4-11 11:13:53 | 显示全部楼层
The meaning of the hardening and tempering steel is 调质钢。
The hardened and tempered steel shows that the 调质钢 has been heat-treated.
 楼主| 发表于 2009-4-11 15:46:06 | 显示全部楼层
回复 2# 陆丰 的帖子
I see. Thank you very much!
发表于 2009-4-12 16:01:45 | 显示全部楼层
the first is 调质钢.
发表于 2009-4-13 15:33:53 | 显示全部楼层
I think that it should be translated the 淬火+回火钢及硬化钢
签到天数: 6 天
发表于 2009-5-12 10:52:43 | 显示全部楼层
floor 2 combine english with chinese ,I appreciate you
发表于 2009-6-12 21:38:50 | 显示全部楼层
It's right
GMT+8, 2026-6-28 17:20 , Processed in 0.028303 second(s), 20 queries .
