查看: 9015|回复: 9
[Help] About induction hardened surface layer grain size
发表于 2009-4-19 16:44:43 | 显示全部楼层 |阅读模式
"If nothing else is indicated, the grain size in the induction hardened surface layer be ISO index G=7 or finer which corresponds to an average grain size of max 30μm. "
What's mean "ISO index G=7"?
I guess it is"Grade 7" , but Idon't know which ISO standard? And which chinese standard corresponds to it?
Please help me! thank you very much!
发表于 2009-4-19 19:35:25 | 显示全部楼层
I think that ISO refers to International Standardization Organization.
" index"should be interpreted as "provision".
发表于 2009-4-23 11:15:25 | 显示全部楼层
you can search the iso spec on the web site.
but I think you just need know the "corresponds to an average grain size of max 30μm"
发表于 2009-4-23 11:17:15 | 显示全部楼层
发表于 2009-4-23 17:26:05 | 显示全部楼层
In the first page in the some GB/T standards, you can see GB****=ISO*****, that mean the info in the 2 standard is the same, pls find the the GB standard about grain size evaluation,if the you can see  GB****=ISO*****, word ,that mean the same info with ISO, then it can be referenced.
签到天数: 50 天
发表于 2009-4-24 14:06:31 | 显示全部楼层
the standard GB is GB/T6394-2002
参与人数 1热处理币 +6 收起 理由
lanwenbiao + 6 我很赞同!
签到天数: 46 天
发表于 2009-5-26 16:27:45 | 显示全部楼层
原帖由 jysh81 于 2009-4-24 14:06 发表
GB and ISO are very identical in terms of grain size.
发表于 2010-1-12 10:47:46 | 显示全部楼层
You can also refer ASTM E112.
签到天数: 7 天
发表于 2010-4-23 11:42:32 | 显示全部楼层
Many GB standards copy or refer to other countrys`, such as Japanese and American. Nowdays, in order to make all standards follow in all countrys of the world. Those people who called "ISO" make the ISO standards.
签到天数: 6 天
发表于 2010-5-8 15:13:35 | 显示全部楼层
Grade 7 in GB/T6394-2002,And the size is 28.24um,so it is equal to the  iso standard you provide !
GMT+8, 2026-6-28 17:03 , Processed in 0.031651 second(s), 22 queries .
