查看: 8330|回复: 6
[Help] what is the meaning of k/h
发表于 2009-8-17 15:59:32 | 显示全部楼层 |阅读模式
hello every one
i read a message recently about the heating speed! it shows a unit of K/h. i can not get it. can some body help me to explain it?
thank you very much1
发表于 2009-8-17 16:27:04 | 显示全部楼层
K-----------absolute temperature?
签到天数: 671 天
发表于 2009-8-17 17:36:37 | 显示全部楼层
yes,it is  absolute temperature!
k=c+273.15
绝对温标,热力学温标  kelvin; absolute temperature scale; absolute thermometric scale; absolute scale
参与人数 1热处理币 +2 收起 理由
bill_bush + 2 感谢支持!
 楼主| 发表于 2009-8-19 15:07:26 | 显示全部楼层
thank you very much!
发表于 2009-8-19 15:17:43 | 显示全部楼层
这个问题我也遇到过,在CQI-9里面就有要求温度的降温速度是40K/h,其实这个问题很好回答,不管是降温速率多少K/h,其实和/h是一样的,都是绝对速率。
呵呵
发表于 2009-9-8 16:32:01 | 显示全部楼层
it's normally means  the cooling speed.
发表于 2009-9-9 08:29:18 | 显示全部楼层
when it is a unit, K/h is equal to ℃/h in number
GMT+8, 2026-6-28 18:14 , Processed in 0.032106 second(s), 22 queries .
