查看: 7595|回复: 0
ASTM D 903 – 98 剥离强度实验标准(英文版)
发表于 2009-11-28 14:08:50 | 显示全部楼层 |阅读模式
感觉很有用处,大家可以下载下来看看
Standard Test Method for
Peel or Stripping Strength of Adhesive Bonds1
This standard is issued under the fixed designation D 903; the number immediately following the designation indicates the year of
original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A
superscript epsilon (e) indicates an editorial change since the last revision or reapproval.
This standard has been approved for use by agencies of the Department of Defense.
GMT+8, 2026-7-19 02:57 , Processed in 0.028040 second(s), 22 queries .
