查看: 4805|回复: 0
[讨论] 机械模具术语(零件、运水、流道、入水)
发表于 2009-11-30 18:59:38 | 显示全部楼层 |阅读模式
入水:gate
  进入位: gate location
  水口形式:gate type
  大水口:edge gate
  细水口: pin-point gate
   水口大小:gate size
  转水口: switching runner/gate
  唧嘴口径: sprue diameter
      运水:water line
  喉塞:line lpug
  喉管:tube
  塑胶管:plastic tube
  快速接头:jiffy quick connector plug/socker
      挡板:stop plate
  定位圈:locating ring
  锁扣:latch
  扣鸡:parting lock set
  推杆:push bar
  栓打螺丝:S.H.S.B
  顶板:eracuretun
  活动臂:lever arm
  分流锥:spure sperader
  水口司:bush
  垃圾钉:stop pin
  隔片:buffle
  弹弓柱:spring rod
  弹弓:die spring
  中托司:ejector guide bush
  中托边:ejector guide pin
  镶针:pin
  销子:dowel pin
  波子弹弓:ball catch
  喉塞: pipe plug
  锁模块:lock plate
  斜顶:angle from pin
  斜顶杆:angle ejector rod
  尼龙拉勾:parting locks
  活动臂:lever arm
  复位键、提前回杆:early return bar
  气阀:valves
  斜导边:angle pin 本帖最后由 sdust 于 2009-12-2 14:18 编辑
GMT+8, 2026-7-18 02:29 , Processed in 0.026775 second(s), 22 queries .
