签到天数: 2947 天 [LV.Master]伴坛终老
发表于 2009-12-4 05:55:35
显示全部楼层
唐山天捷的东家就是北京Aichelin,见:http://www.rclbbs.com/viewthread.php?tid=32569
SEW不也是Aichelin的客户吗?,那你们也可以牙还牙嘛
以下原文引用至爱协林网站新闻:
New order: Fully automatic Double-continous-chamber furnace Plant for SEW
AICHELIN has received an order for a fully automatic double continuous chamber furnace line from its long-time customer SEW Eurodrive (Bruchsal, Germany), the recognised market leader of drive technology.
AICHELIN had to comply with SEW special requirement for assurance of highest maintainability for its furnaces. We realized this particularly high degree of maintainability of its chamber furnace plants by abolition of the safety fence while simultaneously ensuring the safety of the plant.This means in particular that in order to avoid the endangering of persons in the area of the moving cart, special safety precautions, such as for example additional sensors, were installed.
The chamber furnace line, which is going to be installed at SEW Bruchsal site, consists of four double continuous chamber furnaces with charge dimensions of 1500 x 900 x 1300 mm3 (LxWxH) and a possible gross charge weight of 1800 kg each.
In addition to the requirements - highest ease of maintenance and operation - this chamber furnace plant fulfils the criteria of highest energy efficiency and operation of the furnace plant without the use of cooling water. |
