查看: 18687|回复: 19
[求助] 如何提高316L锻件固溶处理后的硬度
发表于 2009-12-19 10:58:45 | 显示全部楼层 |阅读模式
一批环型锻件,直径500MM,
固溶(1050度)热处理后锻件硬度只有140-150?
请各们分析一下,为什么只有这么低的硬度。如何解决
签到天数: 52 天
发表于 2009-12-19 15:45:39 | 显示全部楼层
正常的硬度值,奥氏体不锈钢304,316等固溶处理后的硬度基本都在140HB左右。
签到天数: 21 天
发表于 2009-12-20 10:27:14 | 显示全部楼层
304,316在不锈钢中硬度是比较低的,你们的产品要想把硬度做起来很难的
 楼主| 发表于 2009-12-21 22:16:10 | 显示全部楼层
原来是这样呀,我的印度客户要求160HB以上!怎么办?
签到天数: 29 天
发表于 2009-12-22 08:02:10 | 显示全部楼层
316L冷作硬化倾向比较明显,如果只要表面硬,可以喷丸处理,如果要整体硬,可以考虑修改工艺,固溶处理后增加少量的冷变形.
 楼主| 发表于 2009-12-23 09:48:18 | 显示全部楼层
小卖部长 发表于 2009-12-22 08:02
谢谢部门回复。
因为我们这次只做锻件,也就是不进行精加工,所以客户收到货后,还要进行精加工,
如果做喷沙处理的话,那应该是只有表面硬度加大,客户加工后,硬度要下来的。
现在锻件已经基本成型(环型锻件),怎么样做冷变形呀?
下面的我的客户给我的回复,请帮我分析一下,看看有没有更好的办法,使硬度达到150HB。
Dear Vince,
We are going to have hardness requirement for 160HB in future orders.   Hence pl. continue your research & development to achieve hardness of minimum 160HB.   Our other supplier able to achieve higher hardness by giving higher Chrome & Nitrogen to the max allow as per std.
As per discussion with our Design Dept. I confirm herewith for this particular order we will accept minimum hardness 150HB.
Best Regards,
Talekar
For item 1 of PO IBC350314, the special requirement of HARDNESS is Min. 160HB.
I study the ASTM A182 F316 and VMS-034 REV09 standard,and do not find the requirement for the hardness in the both standards.
As far as i am concerned,for the stainless steel contented low carbon( i.e.F316/F316L/F304) the normal hardness is about 140HB.
It is very difficult to increase the hardness to 160HB by heat-treatment procedure.
The hardness value is 141HB on the test bar.
Tensile Strength=537Mpa
Yield Strength=241Mpa
Elongation=63.6%
Reduction of Area=73%
We try & test heat treatment for test bar several times, but the hardness value can not reach to 160HB.
Please kindly offer your comment!
vince
签到天数: 29 天
发表于 2009-12-23 10:29:08 | 显示全部楼层
已经到了尺寸的话,我也不知道该怎么办了,不过用户如果进行切削加工的话,加工完表面硬度肯定会提高的.
 楼主| 发表于 2009-12-23 10:34:14 | 显示全部楼层
小卖部长 发表于 2009-12-23 10:29
你估计能提高多少硬度HB?加工余量估计有2mm
发表于 2009-12-23 17:16:18 | 显示全部楼层
加工时利用冷作硬化提高硬度是不可靠的,这与切削参数及冷却相关,切削量越大挤压变形硬化层越深,有时硬度可达40HRC,但表面光洁度不好。还是需要从材料上想办法,增加碳,铬,钨,铜等微量合金元素。热处理是无法提高316L材料的硬度的。
 楼主| 发表于 2009-12-24 15:44:33 | 显示全部楼层
谢谢各位回复。
发表于 2009-12-25 10:14:01 | 显示全部楼层
冷加工可以,提高材料中N含量,可以提高硬度,316LN这个材料会不会更好点
发表于 2009-12-25 14:41:13 | 显示全部楼层
11# zhangjiejear
楼主可以从固溶工艺上想想办法,降低固溶温度或者采用较慢的冷却速度都有提高硬度的可能。
 楼主| 发表于 2009-12-30 22:06:55 | 显示全部楼层
谢谢各位回答!
正如11楼所说,增加N和Cr的含量确实可以提高硬度!
发表于 2009-12-31 10:18:52 | 显示全部楼层
增加N和Cr的含量确实可以提高硬度!
增N是绝对不可行的,硬度增加易断裂!!!
发表于 2009-12-31 10:20:28 | 显示全部楼层
建议从热处理上考虑.不同温度和冷却速度下固溶处理.
不过要提要那么多,不太容易
发表于 2009-12-31 16:26:05 | 显示全部楼层
316L 成分:Ni:10-14,Cr:16-18,固溶后硬度基本在HV130左右,要想达到HB150很难,估计其他供应商给的是316LN,因为提高Ni成本太高了,还不一定能达到HB150-160。
发表于 2009-12-31 16:53:56 | 显示全部楼层
我们自己做的316L的铸件,Cr基本快到 18%了,Ni 在 10%-11%之间,不冷变形之前硬度都达不到HB160,我们买的316L刚带,硬度在HV130左右。
在ASTM A 276-08a(08年a版)中 316L没有对N含来限制 ,316LN中 N含量为:0.10-0.16%
    ASTM A 276-96                         中 316L中N<0.10%,               316LN中 N含量为:0.10-0.16%
他说其他供应商靠提高Cr和Ni 来达到HB 150-160的,是想向你们施加价格压力也说不定。
签到天数: 6 天
发表于 2013-7-23 12:38:45 | 显示全部楼层
你好,你们这个问题解决了吗。如何解决的!!
发表于 2013-7-23 12:58:26 | 显示全部楼层
固溶后,可以先预冷到980左右再淬火
签到天数: 11 天
发表于 2013-8-8 09:24:29 | 显示全部楼层
真空炉热处理好不好操作,天天听说真空热处理www.gpcuihuo.com
GMT+8, 2026-7-19 04:44 , Processed in 0.037109 second(s), 21 queries .
