查看: 9041|回复: 3
[分享] 布氏硬度与洛氏硬度换算表
发表于 2007-6-25 20:04:00 | 显示全部楼层 |阅读模式
布氏硬度与洛氏硬度换算表
签到天数: 463 天
发表于 2007-11-18 01:41:44 | 显示全部楼层
签到天数: 463 天
发表于 2007-11-24 09:56:15 | 显示全部楼层
硬度换算表: 布氏硬度与洛氏硬度
布氏硬度        洛氏硬度        抗拉强度        布氏硬度        洛氏硬度        抗拉强度
硬质合金球HB
3000kg        标尺HRA
60kg        标尺HRB
100kg        标尺HRC
150kg        (约磅/英寸2)        硬质合金球 HB
000kg        标尺HRA
60Kg        标尺HRB
100kg        标尺HRC
150kg        (约磅/英寸2)
-        85.6        -        68.0        -        331        68.1        -        35.5        166,000
-        85.3        -        67.5        -        321        67.5        -        34.3        160,000
-        85.0        -        67.0        -        311        66.9        -        33.1        155,000
767        84.7        -        66.4        -        302        66.3        -        32.1        150,000
757        84.4        -        65.9        -        293        65.7        -        30.9        145,000
745        84.1        -        65.3        -        285        65.3        -        29.9        141,000
733        83.8        -        64.7        -        277        64.6        -        28.8        137,000
722        83.4        -        64.0        -        269        64.1        -        27.6        133,000
712        -        -        -        -        262        63.6        -        26.6        129,000
710        83.0        -        63.3        -        255        63.0        -        25.4        126,000
698        82.6        -        62.5        -        248        62.5        -        24.2        122,000
684        82.2        -        61.8        -        241        61.8        100.0        22.8        118,000
682        82.2        -        61.7        -        235        61.4        99.0        21.7        115,000
670        81.8        -        61.0        -        229        60.8        98.2        20.5        111,000
656        81.3        -        60.1        -        223        -        97.3        20.0        -
653        81.2        -        60.0        -        217        -        96.4        18.0        105,000
647        81.1        -        59.7        -        212        -        95.5        17.0        102,000
638        80.8        -        59.2        329,000        207        -        94.6        16.0        100,000
630        80.6        -        58.8        324,000        201        -        93.8        15.0        98,000
627        80.5        -        58.7        323,000        197        -        92.8        -        95,000
601        79.8        -        57.3        309,000        192        -        91.9        -        93,000
578        79.1        -        56.0        297,000        187        -        90.7        -        90,000
555        78.4        -        54.7        285,000        183        -        90.0        -        89,000
534        77.8        -        53.5        274,000        179        -        89.0        -        87,000
514        76.9        -        52.1        263,000        174        -        87.8        -        85,000
495        76.3        -        51.0        253,000        170        -        86.8        -        83,000
477        75.6        -        49.6        243,000        167        -        86.0        -        81,000
461        74.9        -        48.5        235,000        163        -        85.0        -        79,000
444        74.2        -        47.1        225,000        156        -        82.9        -        76,000
429        73.4        -        45.7        217,000        149        -        80.8        -        73,000
415        72.8        -        44.5        210,000        143        -        78.7        -        71,000
401        72.0        -        43.1        202,000        137        -        76.4        -        67,000
388        71.4        -        41.8        195,000        131        -        74.0        -        65,000
375        70.6        -        40.4        188,000        126        -        72.0        -        63,000
363        70.0        -        39.1        182,000        121        -        69.8        -        60,000
352        69.3        -        37.9        176,000        116        -        67.6        -        58,000
硬度对照表是不对的
这个表是不是不对啊,各位老大看看!
发表于 2007-12-5 21:38:57 | 显示全部楼层
GMT+8, 2026-7-17 16:56 , Processed in 0.029238 second(s), 22 queries .
