查看: 6477|回复: 0
ASTM A 645/A 645M-99a Standard Specification for Pressure Vessel Plates, Five Pe
发表于 2007-6-27 08:05:23 | 显示全部楼层 |阅读模式
ASTM A 645/A 645M-99a Standard Specification for Pressure Vessel Plates, Five Percent Nickel Alloy Steel,Specially Heat Treated
ASTM A 645/A 645M-99a 压力容器用经特殊热处理的5%镍合金钢板的标准规范
GMT+8, 2026-7-19 00:38 , Processed in 0.027258 second(s), 22 queries .
