查看: 6006|回复: 12
Metallurgical position at Timken
发表于 2010-3-31 18:16:44 | 显示全部楼层 |阅读模式
We have 2 open positions at Timken.
1. Metallurgical supervisor
    Generally, this position is for Timken Wuxi bearing plant, and is very urgent. This associate will responsible for the metallurgical lab and the plant metallurgical issues. If you're interested, you can get more information from Internet.
2. Sr. Materials Engineer / Principle Materials Engineer
   This position is recruited by Timken China Holding Company. Main responsibility,
1.        Metallurgical support for Timken sourcing projects.
2.        Audit the steel, forging, HT, casting and coating supplier.
3.        Failure analysis of customer returns.
4.        Guide the metallurgical inspection for the technicians, also involved in Timken metallurgical research.
5.        Support Timken China facilities.
The formal recruiting notice will be posted soon. If you have any other questions, please contact with me.
If you have interest, pls send your resume to my mail box.
zhouhf@timken.com
发表于 2010-3-31 18:54:20 | 显示全部楼层
one hunter sent my updated cv to you this Jan. it seems that I couldn't any feedback
签到天数: 8 天
发表于 2010-3-31 19:19:28 | 显示全部楼层
跑这儿装洋枪来了,丢脸!
签到天数: 333 天
发表于 2010-3-31 19:31:10 | 显示全部楼层
楼主是HF吗?
这两个职位很诱人的,尤其是第一个,第二个空了一段时间了。
XM走后,我以前公司的一个硕士朋友通过猎头应聘过那个职位,因工作经验只有2年没成功。
如果直接通过工厂可能会好些吧。
如果有意,请联系我。
发表于 2010-4-4 20:38:44 | 显示全部楼层
我发了简历给你,你看看吧~~我应聘金相工程师~~~
签到天数: 6 天
发表于 2010-4-5 08:52:58 | 显示全部楼层
我也应聘金相主管!
签到天数: 333 天
发表于 2010-4-5 20:13:09 | 显示全部楼层
回复楼上:
这个职位是冶金工程师,不只是单纯的金相.
此职位在该公司是一个不错的职位,有出国培训的机会.
无锡工厂是TIMKEN在中国最大的工厂.
签到天数: 46 天
发表于 2010-4-5 22:28:28 | 显示全部楼层
学位,工作年限要求?薪资?
发表于 2010-4-7 22:18:01 | 显示全部楼层
supervisor不稀奇,后面那个职位不是谁随便能做到。
可惜了,在无锡
签到天数: 6 天
发表于 2010-4-8 18:55:31 | 显示全部楼层
很想去无锡工作啊!
 楼主| 发表于 2010-4-15 16:51:25 | 显示全部楼层
第一个职位已经基本敲定。
签到天数: 98 天
发表于 2010-5-12 16:22:46 | 显示全部楼层
我的乖乖,全是洋文啊。
签到天数: 98 天
发表于 2010-5-12 16:24:02 | 显示全部楼层
回复 7# 察哈尔汗
    张同学,你说的我都心动了,呵呵
GMT+8, 2026-7-19 14:32 , Processed in 0.034903 second(s), 21 queries .
