查看: 8126|回复: 4
[Help] pit corrosion on the teeth after carbonization and quenching
发表于 2010-4-27 20:34:48 | 显示全部楼层 |阅读模式
our gears and shafts always exist the pit corrosion on its teeth after quenching and tempering.  this phenomenon generally occur near the top of teeth. the IG0  depth meet the requirement . who can tell me what will cause this case happen?
签到天数: 332 天
发表于 2010-4-28 22:14:47 | 显示全部楼层
发表于 2010-4-29 11:27:08 | 显示全部楼层
前处理工件表面不干净
bill_bush + 10 感谢支持!
发表于 2010-5-3 19:33:17 | 显示全部楼层
会不会是淬火后,没清洗干净就回火造成?
 楼主| 发表于 2010-5-10 20:45:20 | 显示全部楼层
thank you for you help.
through we checking, the main reason is the pre-heat tresatment cleanliness .
GMT+8, 2026-6-28 16:09 , Processed in 0.029574 second(s), 22 queries .
