查看: 3797|回复: 0
ASTM A255-10(R2018) Standard Test Methods for Determining Hardenability of Steel
签到天数: 2946 天
发表于 2024-4-15 17:14:31 | 显示全部楼层 |阅读模式
Designation: A255-10 (Reapproved 2018)
This standard is issued under the fixed designation A255; the number immediately following the designation indicates the year of original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A superscript epsilon (´) indicates an editorial change since the last revision or reapproval.
This standard has been approved for use by agencies ofthe U.S. Department ofDefense
GMT+8, 2026-7-18 22:23 , Processed in 0.027111 second(s), 22 queries .
