查看: 6637|回复: 0
[分享] AIAG CQI-7 ISO/TS 16949:2002 IMPLEMENTATION GUIDE(英文)
发表于 2007-7-7 15:16:43 | 显示全部楼层 |阅读模式
什么是CQI-9?
CQI-9:特殊过程-热处理系统审核。由美国汽车工业行动集团(AIAG)热处理工作小组起草并获得技术委员会批准。发布日期:2006年3月。
CQI-9特殊过程:热处理审核的准备工作由AIAG热处理工作小组完成,这些热处理系统审核要求是对顾客和产品要求的补充。HTSA(Heat Treat System Assessment)用于评审组织满足本要求、顾客、法规及组织自身要求的能力,同时也适用于组织和它的供应商之间。
CQI-9官方说明(附本站翻译)
Heat Treat System Assessment (HTSA) Update
热处理系统评估(HTSA)更新
The International Automotive Oversight Bureau (IAOB) has recommended that Heat Treat System Assessment (HTSA) auditors become familiar with CQI-9 and include verification of supplier compliance when conducting these audits.This verification should be included in audit plans by the end of 2006.
国际汽车监督局(IAOB)建议,热处理系统评估(HTSA)审计员熟悉CQI-9包括核查供应商履约进行时,这些审计结果. 这项核查工作应列入审计计划,2006年年底前结束.
The goal of HTSA is to develop a heat treat management system that provides for continual improvement, emphasizes defect prevention and the reduction of variation and waste in the supply chain.HTSA provides a common approach to a heat treat management system for automotive production and service part organizations.
HTSA的目标是制订热处理工艺管理体系,为持续改进强调缺陷预防,减少变异及浪费的供应链. HTSA提供了一个共同的方式,以热处理工艺管理系统,用于汽车生产和服务组织的一部分.
Unless otherwise specified by customers, future requirements indicate that assessments must be conducted annually to re-examine the continuing compliance with the HTSA.As part of the on-going surveillance audit cycles, corrective actions are required for any unsatisfactory areas.
除非法律另有规定,客户未来的要求表明,评估工作必须每年进行一次重新审核继续遵守.作为上持续监视审计周期,纠正行动所需的任何不理想的地方.
Many North American Original Equipment Manufacturers (OEMs) consider this to be a "Customer-Specific Requirement" and expect compliance from any ISO/TS 16949 registered companies.
许多北美原始设备制造商(OEM)认为这是一种"以客户的具体要求",并期望从遵守任何ISO/TS 16949注册公司
GMT+8, 2026-6-28 21:35 , Processed in 0.027153 second(s), 22 queries .
