查看: 11802|回复: 7
[Help] How to upload the attachment more than 2M?
发表于 2010-10-29 15:51:41 | 显示全部楼层 |阅读模式
Hi, guys, I want to share my standard. But it's more than 2M that is more than the permitting value of the bbs. Does anyone have the solution to solve it? If so pls. write down the answer on the responding area. Thx.
发表于 2010-11-4 23:58:40 | 显示全部楼层
I have the sane problem with you
发表于 2010-11-5 10:31:01 | 显示全部楼层
You can try sub-volume compression, and then upload.
 楼主| 发表于 2010-11-5 14:35:23 | 显示全部楼层
回复 3# 上尉连长
Yes, I've tried. The proplem is after compression, the volume is still more than 2M. It feazes me to the hell.
发表于 2010-11-5 14:59:05 | 显示全部楼层
This is really incredible.I use WINARA3.9,and I can compress  a  4M  file  into  three documents.Everyone of it isn't  more than 1.5M.
发表于 2011-7-27 16:48:12 | 显示全部楼层
You dirty man. cut it out,don't waste your time on this kind of stuff.
it's up to the regulation of the forum.      Impossible here!
点评
Verbal abuse is not allowed here!  发表于 2011-7-28 12:48
参与人数 1热处理币 -10 收起 理由
chenze2008 -10 违规内容!
发表于 2011-7-28 15:19:30 | 显示全部楼层
it's up to the regulation of ...
My God, I took a joke with my classmate here
发表于 2011-7-29 10:16:17 | 显示全部楼层
ask BZfor help maybe  he could give you some advise useful
GMT+8, 2026-7-18 18:51 , Processed in 0.032062 second(s), 24 queries .
