查看: 5838|回复: 6
金属材料及热处理工艺常用基础英语词汇翻译对照1
发表于 2010-12-29 11:15:54 | 显示全部楼层 |阅读模式
X线结晶分析法 X – ray crystal analyics method
  奥氏体 Austenite
  奥氏体碳钢 Austenite Carbon Steel
  奥氏铁孻回火 Austempering
  半静钢 Semi-killed steel
  包晶反应 Peritectic Reaction
  包晶合金 Peritectic Alloy
  包晶温度 Peritectic Temperature
  薄卷片及薄片(0.3至2.9mm厚之片)机械性能 Mechanical Properties of Thin Stainless Steel(Thickness from 0.3mm to 2.9mm) – strip/sheet
  杯突测试(厚度: 0.4公厘至1.6公厘,准确至0.1公厘 3个试片平均数) Erichsen test (Thickness: 0.4mm to 1.6mm, figure round up to 0.1mm)
  贝氏体钢片 Bainite Steel Strip
  比电阻 Specific resistivity & specific resistance
  比较抗磁体、顺磁体及铁磁体 Comparison of Diamagnetism, Paramagnetic & Ferromagnetism
  比热 Specific Heat
  比重 Specific gravity & specific density
  边缘处理 Edge Finish
  扁线、半圆线及异形线 Flat Wire, Half Round Wire, Shaped WirePrecision Shaped Fine Wire
  扁线公差 Flat Wire Tolerance
  变态点 Transformation Point
  表面保护胶纸 Surface protection film
  表面处理 Surface finish
  表面处理 Surface Treatment
  不破坏检验 Non – destructive inspections
  不锈钢 Stainless Steel
  不锈钢 – 种类,工业标准,化学成份,特点及 主要用途 Stainless Steel – Type, Industrial Standard, Chemical Composition, Characteristic & end usage of the most commonly used Stainless Steel
  不锈钢薄片用途例 End Usage of Thinner Gauge
  不锈钢扁线及半圆线常用材料 Commonly used materials for Stainless Flat Wire & Half Round Wire
  不锈钢箔、卷片、片及板之厚度分类 Classification of Foil, Strip, Sheet & Plate by Thickness
  不锈钢材及耐热钢材标准对照表 StainlessHeat-Resisting Steels
  不锈钢的磁性 Magnetic Property & Stainless Steel
  不锈钢的定义 Definition of Stainless Steel
  不锈钢基层金属 Stainless Steel as Base Metal
  不锈钢片、板用途例 Examples of End Usages of Strip, Sheet & Plate
  不锈钢片材常用代号 Designation of SUS Steel Special Use Stainless
  不锈钢片机械性能(301, 304, 631, CSP) Mechanical Properties of Spring use Stainless Steel
  不锈钢应力退火卷片常用规格名词图解 General Specification of Tension Annealed Stainless Steel Strips
  不锈钢之分类,耐腐蚀性及耐热性 Classification, Corrosion Resistant & Heat Resistance of Stainless Steel
  材料的加工性能 Drawing abillity
  插入型固熔体 Interstital solid solution
  常用尺寸 Commonly Used Size
  常用的弹簧不锈钢线-编号,特性,表面处理及化学成份 StainlessSpring Wire – National Standard number, Charateristic, Surface finish & Chemical composition
  常用的镀锌钢片(电解片)的基层金属、用途、日工标准、美材标准及一般厚度 Base metal, application, JIS & ASTM standard,Normal thickness of galvanized steel sheet
  长度公差 Length Tolerance
  超耐热钢 Special Heat Resistance Steel
  超声波探伤法 Ultrasonic inspection
  冲击测试 Impact Test
  冲剪 Drawing & stamping
  初释纯铁体 Pro-entectoid ferrite
  处理及表面状况 Finish & Surface
  纯铁体 Ferrite
  磁场 Magnetic Field
  磁畴 Magnetic domain
  磁粉探伤法 Magnetic particle inspection
  磁化率 Magnetic Susceptibility (Xm)
  磁矩 magnetic moment
  磁力 Magnetic
  磁力 Magnetic Force
  磁偶极子 Dipole
  磁性 Magnetisum
  磁性变态 Magnetic Transformation
  磁性变态点 Magnetic Transformation
  磁性感应 Magnetic Induction
  粗珠光体 Coarse pearlite
  淬火 Quenching
  淬火及回火状态 Hardened & Tempered Strip/ Precision – Quenched Steel Strip
  淬火剂 Quenching Media
  单相金属 Single Phase Metal
  单相轧压镀锡薄铁片(白铁皮/马口铁) Single-Reduced Tinplate
  弹簧不锈钢线,线径及拉力列表 Stainless Spring Steel, Wire diameterTensile strength of Spring Wire
  弹簧用碳钢片 CarbonSteel Strip For Spring Use
  弹簧用碳钢片材之边缘处理 Edge Finished
  弹性限度、阳氏弹性系数及屈服点 elastic limit, Yeung''s module of elasticity to yield point
  倒后擦发条 Pull Back Power Spring
  导热度 Heat conductivity
  低碳钢或铁基层金属 Iron & Low Carbon as Base Metal
  低碳马氏体不锈钢 Low Carbon Martensite Stainless Steel
  低温脆性 Cold brittleness
  低温退火 Low Temperature Annealing
  第二潜变期 Secondary Creep
  第三潜变期 Tertiary Creep
  第壹潜变期 Primary Creep
  点焊 Spot welding
  电镀金属钢片 Plate Metal Strip
  电镀金属捆片的优点 Advantage of Using Plate Metal Strip
  电镀锌(电解)钢片 Electro-galvanized Steel Sheet
  电镀锌钢片的焊接 Welding of Electro-galvanized steel sheet
  电镀锌钢片或电解钢片 Electro-galvanized Steel Sheet/Electrolytic Zinc Coated Steel Sheet
  电解/电镀锌大大增强钢片的防锈能力 Galvanic Action improving Weather & Corrosion Resistance of the Base Steel Sheet
  电解冷轧钢片厚度公差 Thickness Tolerance of Electrolytic Cold-rolled sheet
  电炉 Electric furnace
  电器及家电外壳用镀层冷辘 [低碳] 钢片 Coated (Low Carbon) Steel Sheets for Casing,Electricals & Home Appliances
  电器用的硅 [硅] 钢片之分类 Classification of Silicon Steel Sheet for Electrical Use
  电器用钢片的绝缘涂层 Performance of Surface Insulation of Electrical Steel Sheets
  电器用钢片用家需自行应力退火原因 Annealing of the Electrical Steel Sheet
  电器用硅 [硅] 钢片 Electrical Steel Sheet
  电阻焊 Resistance Welding
  定型发条 Constant Torque Spring
  定型发条的形状及翻动过程 ShapeSpring Back of Constant Torque Spring
  定型发条及上炼发条的驱动力 Spring Force of Constant Torque SpringWing-up Spring
  定型发条驱动力公式及代号 The FormulaSymbol of Constant Torque Spring
  镀层质量标记 Markings & Designations of Differential Coatings
  镀铬 Chrome Plated
  镀黄铜 Brass Plated
  镀铝(硅)钢片 – 美材试标准(ASTM A-463-77)35.7 JIS G3314镀热浸铝片的机械性能 Mechanical Properties of JIS G 3314 Hot-Dip Aluminum-coated SheetsCoils
  镀铝(硅)钢片 – 日工标准(JIS G3314) Hot-aluminum-coated sheetscoils to JIS G 3314
  镀铝(硅)钢片及其它种类钢片的抗腐蚀性能比较 Comparsion of various resistance of aluminized steel & other kinds of steel
  镀铝(硅)钢片生产流程 Aluminum Steel Sheet, Production Flow Chart
  镀铝硅钢片 Aluminized Silicon Alloy Steel Sheet
  镀铝硅合金钢片的特色 Feature of Aluminized Silicon Alloy Steel Sheet
  镀镍 Nickel Plated
  镀锡薄钢片(白铁皮/马日铁)制造过程 Production Process of Electrolytic Tinplate
  镀锡薄铁片(白铁皮/马口铁) (日工标准 JIS G3303)
  镀锡薄铁片的构造 Construction of Electrolytic Tinplate
  锻造 Fogging
  断面缩率 Reduction of area
  发条的分类及材料 Power Spring Strip ClassificationMaterials
  发条片 Power Spring Strip
  反铁磁体 Antiferromagnetism
  方线公差 Square Wire Tolerance
  防止生锈 Rust Protection
  放射线探伤法 Radiographic inspection
  非晶粒取向电力用钢片的电力、磁力、机械性能 及夹层系数 Lamination Factors of Electrical, Magnetic & Mechanical Non-Grain Oriented Electrical
  沸腾钢(未净钢) Rimmed steel
  分类 Classification
  负磁力效应 Negative effect
  钢板 Steel Plate
  钢板订货需知 Ordering of Steel Plate
  钢板生产流程 Production Flow Chart
  钢板用途分类及各国钢板的工业标准包括日工标准及美材试标准 Type of steel Plate & Related JIS, ASTMOther Major Industrial Standards
  钢材的熔铸、锻造、挤压及延轧 The Casting, Fogging, Extrusion, Rolling & Steel
  钢的脆性 Brittleness of Steel
  钢的种类 Type of Steel
  钢铁的名称 Name of steel
  钢铁的制造 Manufacturing of Steel
  钢铁的主要成份 The major element of steel
  钢铁生产流程 Steel Production Flow Chart
  钢铁用“碳”之含量来分类 Classification of Steel according to Carbon contents
  高锰钢铸 – 日工标准 High manganese steel to JIS standard
  高碳钢化学成份及用途 High Carbon Tool Steel, Chemical CompositionUsage
  高碳钢片 High Carbon Steel Strip
  高碳钢片用途 End Usage of High Carbon Steel Strip
  高碳钢线枝 High Carbon Steel Wire Rod (to JIS G3506)
  高温回火 High Temperature Tempering
  格子常数 Lattice constant
  铬钢 – 日工标准 JIS G4104 Chrome steel to JIS G4104
  铬镍不锈钢及抗热钢弹簧线材–美国材验学会 ASTM A313 – 1987 Chromium – Nickel StainlessHeat-resisting Steel Spring Wire – ASTM A313 – 1987
  铬系耐热钢 Chrome Heat Resistance Steel
  铬钼钢钢材 – 日工标准 G4105 62 Chrome Molybdenum steel to JIS G4105
  各种不锈钢线在不同处理拉力比较表 Tensile Strength of various kinds of Stainless Steel Wire under Different Finish
  工业标准及规格 – 铁及非铁金属 Industrial Standard – Ferrous & Non – ferrous Metal
  公差 Size Tolerance
  共晶 Eutectic
  共释变态 Eutectoid Transformation
  固熔体 Solid solution
  光辉退火 Bright Annealing
  光线(低碳钢线),火线(退火低碳钢线),铅水线 (镀锌低碳钢线)及制造钉用低碳钢线之代号、公差及备注 Ordinary Low Carbon Steel Wire, Annealed Low Carbon Steel Wire, Galvanized low Carbon Steel Wire & Low Carbon Steel Wire for nail manufacturing - classification, Symbol of Grade, ToleranceRemarks.
  硅含量对电器用的低碳钢片的最大好处 The Advantage of Using Silicon low Carbon Steel
  滚焊 Seam welding
  过共晶体 Hyper-ectectic Alloy
  过共释钢 Hype-eutectoid
  含硫易车钢 Sulphuric Free Cutting Steel
  含铅易车钢 Leaded Free Cutting Steel
  含铁体不锈钢 Ferrite Stainless Steel
  焊接 Welding
  焊接合金 SolderingBrazing Alloy
  焊接能力 Weldability 镀铝钢片的焊接状态(比较冷辘钢片) Tips on welding of Aluminized sheet in comparasion with cold rolled steel strip
  合金平衡状态 Thermal Equilibrium
  厚度及阔度公差 Tolerance on Thickness & Width
  滑动面 Slip Plan
  化学成份 Chemical Composition
  化学结合 Chemical bond
  化学性能 Chemical Properties
  化学元素 Chemical element
  黄铜基层金属 Brass as Base Metal
  回复柔软 Crystal Recovery
  回火脆性 Temper brittleness
  回火有低温回火及高温回火 Low & High Temperature Tempering
  回火状态 Annealed Strip
  基层金属 Base Metal of Plated Metal Strip
  机械性能 Mechanical Properites
  机械性能 Mechanical properties
  畸变 Distortion
  级别、电镀方法、镀层质量及常用称号 Grade, Plating type, Designation of Coating Mass & Common Coating Mass
  级别,代号,扭曲特性及可用之线材直径 Classes, symbols, twisting characteristicapplied Wire Diameters
  级别,代号及化学成份 Classification, Symbol of GradeChemical Composition
  挤压 Extrusion
  加工方法 Manufacturing Method
  加工性能 Machinability
  简介 General
  交换能量 Positive energy exchange
  矫顽磁力 Coercive Force
  金属变态 Transformation
  金属材料的试验方法 The Method of Metal inspection
  金属材料的性能及试验 Properties & testing of metal
  金属的特性 Features of Metal
  金属的相融、相融温度、晶体反应及合金在共晶合金、固熔孻共晶合金及偏晶反应的比较 Equilibrium Comparision
  金属间化物 Intermetallic compound
  金属结晶格子 Metal space lattice
  金属捆片电镀层 Plated Layer of Plated Metal Strip
  金属塑性 Plastic Deformation
  金属特性 Special metallic features
  金属与合金 MetalAlloy
  金相及相律 Metal PhasePhase Rule
  晶粒取向(Grain-Oriented)及非晶粒取向(Non-Oriented)
  晶粒取向,定取向芯钢片及高硼定取向芯钢片之磁力性能及夹层系数(日工标准及美材标准) Magnetic PropertiesLamination Factor of SI-ORIENT-CORE& SI-ORIENT-CORE-HI B Electrical Steel Strip (JISAISI Standard)
  晶粒取向电器用硅 [硅] 钢;片 – 高硼低硫(LS)定取向 钢片之磁力及电力性能 MagneticElectrical Properties of SI-ORIENT-CORE-HI-B-LS
  晶粒取向电器用硅 [硅] 钢片 – 高硼(HI-B)定取向芯钢片及定取向芯钢片之机械性能及夹层系数 Mechanical PropertiesLamination Factors of SI-ORIENT-CORE-HI-BSI-ORIENT-CORE Grain Orient Electrical Steel Sheets
  晶粒取向电器用硅 [硅] 钢片 – 高硼低硫(LS) 定取向钢片之机械性能及夹层系数 Mechanical PropertiesLamination Factors of SI-ORIENT-CORE-HI-B-LS
  晶粒取向电器用硅(硅)钢片 – 高硼(HI-B)定取向芯钢片,定取向芯钢片及高硼低硫(LS)定取向芯钢片之标准尺寸及包装 Standard FormsSize of SI-ORIENT-CORE-HI-B,SI-CORE, & SI-ORIENT-CORE-HI-B-LS Grain-
  晶粒取向电器用硅(硅) 钢片-高硼(HI-B)定取向芯钢片,定取向芯钢片及高硼低硫(LS)定取向芯钢片之厚度及阔度公差 Physical Tolerance of SI-ORIENT-CORE-HI-B, SI-ORIENT-CORE, & SI-CORE-HI-B-LS Grain
  晶粒取向电器用硅钢片 Grain-Oriented Electrical Steel
  晶粒取向电器用硅钢片主要工业标准 International Standard – Grain-Oriented Electrical Steel Silicon Steel Sheet for Electrical Use
  晶体结构 Crystal Pattern
  晶体结构,定向格子及单位晶格 Crystal structure, Space lattice & Unit cell
  净磁矩 Net magnetic moment
  绝缘表面 Surface Insulation
  均热炉 Soaking pit
  抗磁体 Diamagnetism
  抗腐蚀及耐用 Corrosion & resistance durability
  抗化学品能力 Chemical Resistance
  抗敏感及环境保护 Allergic, re-cycling & environmental protection
  抗热超级合金 Heat Resistance Super Alloy
  扩散退火 Diffusion Annealing
  拉尺发条 Measure Tape
  拉伸测试(顺纹测试) Elongation test
  冷冲及冷锻用碳钢线枝 Carbon Steel Wire Rods for Cold Heading & Cold Forging (to JIS G3507)
  冷拉钢板重量表 Cold Drawn Steel Bar Weight Table
  冷拉钢枝材 Cold Drawn Carbon Steel Shafting Bar
  冷拉高碳钢线 Hard Drawn High Carbon Steel Wire
  冷轧钢片 Cold-Rolled Steel Sheet/Strip
  冷轧高碳钢–日本工业标准 Cold-Rolled (Special Steel) Carbon Steel Strip to JIS G3311
  冷轧或热轧钢片阔度公差 Width Tolerance of Cold or Hot-rolled sheet
  冷轧状态 Cold Rolled Strip
  冷辘(低碳)钢片的分类用、途、工业标准、品质、加热状态及硬度表 End usages, industrial standard, quality, conditionhardness of cold rolled steel strip
  冷辘低碳钢片(双单光片)(日工标准 JIS G3141) 73 - 95 Cold Rolled (Low carbon) Steel Strip (to JIS G 3141)
  冷辘钢捆片及张片的电镀和印刷方法 Cold rolled steel coil & sheet electro-plating & painting method
  冷辘钢捆片及张片制作流程图表 Production flow chart cold rolled steel coil sheet
  冷辘钢片(拉力: 30-32公斤/平方米)在没有表面处理状态下的焊接状况 Spot welding conditions for bared (free from paint, oxides etc) Cold rolled mild steel sheets(T/S:30-32 Kgf/ μ m2)
  冷辘钢片储存与处理提示 General advice on handling & storage of cold rolled steel coil & sheet
  冷辘钢片的“理论重量”计算方程式 Cold Rolled Steel Sheet – Theoretical mass
  冷辘钢片订货需知 Ordering of cold rolled steel strip/sheet
  理论质量 Theoretical Mass
  连续铸造法 Continuous casting process
  两面不均等锡层 Both Side Different Thickness Coated Mass
  两面均等锡层 Both Side Equally Coated Mass
  裂纹之容许深度及脱碳层 Permissible depth of flawdecarburized layer
  临界温度 Critical temperture
  马氏体不锈钢 Martensite Stainless Steel
  马氏铁体淬火 Marquenching
  埋弧焊 Submerged-arc Welding
  每公斤发条的长度简易公式 The Length of 1 Kg of Spring Steel Strip
  美材试标准的冷辘低碳钢片 Cold Rolled Steel Strip American Standard – American Society for testingmaterials (ASTM)
  美国工业标准 – 不锈钢及防热钢材的化学成份 (先数字后字母排列) AISI – Chemical Composition of Stainless Steel & Heat-Resistant Steel(in order of number & alphabet)
 楼主| 发表于 2010-12-29 11:19:33 | 显示全部楼层
  金属材料及热处理工艺常用基础英语词汇翻译对照2
      米勒指数 Mill''s Index
  魔术手环 Magic Tape
  魔术手环尺寸图Drawing of Magic Tap
  耐热不锈钢 Heat-Resistance Stainless Steel
  耐热不锈钢比重表 Specific Gravity of Heat – resistance steel platessheets stainless steel
  镍铬 – 日工标准 G4102 63 Chrome Nickel steel to JIS G4102
  镍铬耐热钢 Ni - Cr Heat Resistance Steel
  镍铬系不锈钢 Nickel Chrome Stainless Steel
  镍铬系耐热不锈钢特性、化学成份、及操作温度 Heat-Resistance Stainless Steel
  镍铬钼钢 – 日工标准 G4103 64 Nickel, Chrome & Molybdenum Steel to JIS G4103
  疲劳测试 Fatigue Test
  片及板材 Chapter Four-Strip, Steel & Plate
  平坦度(阔度大于500公厘,标准回火) Flatness (width>500mm, temper: standard)
  破坏的检验 Destructive Inspection
  其它焊接材料请参阅日工标准目录 Other Soldering Material
  其它日工标准冷轧钢片(用途及编号) JIS standard & application of other cold Rolled Special Steel
  气焊 Gas Welding
  潜变测试 Creep Test
  潜变强度 Creeps Strength
  强度 Strength
  琴线(日本标准 G3522) Piano Wires ( to G3522)
  球化退火 Spheroidizing Annealing
  曲面(假曲率) Camber
  屈服强度(降伏强度) (Yield strangth)
  全静钢 Killed steel
  热力应先从工件边缘透入 Heat from the Laminated Stacks Edges
  热膨胀系数 Coefficient of thermal expansion
  热轧钢片 Hot-Rolled Sheet/Strip
  热轧钢片厚度公差 Thickness Tolerance of Hot-rolled sheet
  日本工业标准–不锈钢的化学成份(先数字后字母排列) JIS – Chemical Composition of Stainless Steel (in order of number & alphabet)
  日工标准(JIS G3141)冷辘钢片化学成份 Chemical composition – cold rolled steel sheet to JIS G3141
  日工标准(JIS G3141)冷辘钢片重量列表 Mass of Cold-Rolled Steel Sheet to JIS G3141
  日工标准JIS G3141冷辘低碳钢片(双单光片)的编号浅释 Decoding of cold rolled(Low carbon)steel strip JIS G3141
  日工标准下的特殊钢材 Specail Steel according to JIS Standard
  熔铸 Casting
  软磁 Soft Magnetic
  软磁材料 Soft Magnetic Material
  软焊 Soldering Alloy
  软焊合金 – 日本标准 JIS H 4341 Soldering Alloy to JIS H 4341
  上链发条 Wind-up Spring
  上漆能力 Paint Adhesion
  伸长度 Elongation
  渗碳体 Cementitle
  渗透探伤法 Penetrate inspection
  生锈速度表 Speed of rusting
  时间淬火 Time Quenching
  时间效应(老化)及拉伸应变 Aging & Stretcher Strains
  释出硬化不锈钢 Precipitation Hardening Stainless Steel
  双相辗压镀锡薄钢片(马口铁/白铁皮) Dual-Reduction Tinplate
  顺磁体 Paramagnetic
  碳钢回火 Tempering
  碳污染 Prevent Carbon Contamination
  特点 Characteristic
  特殊钢 Special Steel
  特殊钢以用途来分类 Classification of Special Steel according to End Usage
  特殊钢以原素分类 Classification of Special Steel according to Element
  提防过份氧化 No Excessive Oxidation
  铁磁体 Ferromagnetism
  铁铬系不锈钢片 Chrome Stainless Steel
  铁及非铁金属 Ferrous & Non Ferrous Metal
  铁锰铝不锈钢 Fe / Mn / Al / Stainless Steel
  铁线(低碳钢线)日工标准 JIS G 3532 Low Carbon Steel Wires ( Iron Wire ) to JIS G 3532
  铁相 Steel Phases
  同素变态 Allotropic Transformation
  铜基层金属 Copper as Base Metal
  透磁度 Magnetic Permeability
  退火 Annealing
  退火时注意事项 Annealing Precautionary
  外价电子 Outer valence electrons
  弯度 Camber
  完全退火 Full Annealing
  物理性能 Physical Properties
  物料科学 Material Science
  物料科学定义 Material Science Definition
  锡层质量 Mass of Tin Coating (JIS G3303-1987)
  锡基、铅基及锌基轴承合金比较表 Comparison of Tin base, Lead baseZinc base alloy for Bearing purpose
  细线材、枝材、棒材 Chapter Five Wire, Rod & Bar
  显微观察法 Microscopic inspection
  线材/枝材材质分类及制成品 ClassificationEnd Products of Wire/Rod
  线径、公差及机械性能(日本工业标准 G 3521) Mechanical Properties (JIS G 3521)
  相反旋转 Opposite span
  相律 Phase Rule
  锌包层之重量,铜硫酸盐试验之酸洗次数及测试用卷筒直径 Weight of Zinc-Coating, Number of Dippings in Cupric Sulphate TestDiameters of Mandrel Used for Coiling Test
  锌镀层质量 Zinc Coating Mass
  锌镀层质量(两个不同锌镀层厚度) Mass Calculation of coating (For differential coating)/MM
  锌镀层质量(两个相同锌镀层厚度) Mass Calculation of coating (For equal coating)/MM
  亚共晶体 Hypoeutetic Alloy
  亚铁磁体 Ferrimagnetism
  亚铁释体 Hyppo-Eutectoid
  延轧 Rolling
  颜色 Colour
  易车(快削)不锈钢 Free Cutting Stainless Steel
  易车(快削)不锈钢拉力表 Tensile Strength of Free Cutting Wires
  易车(快削)不锈钢种类 Type of steel
  易车不锈钢及易车钢之不同尺寸及硬度比较 Hardness of Different Types & Size of Free Cutting Steel
  易车碳钢 Free Cutting Carbon Steels (to JIS G4804 )
  易溶合金 Fusible Alloy
  应力退火温度 Stress –relieving Annealing Temperature
  应用材料 Material Used
  硬磁 Hard Magnetic
  硬磁材料 Hard Magnetic Material
  硬度 Hardness
  硬度及拉力 Hardness & Tensile strength test
  硬焊 Brazing Alloy
  硬化 Work Hardening
  硬化性能 Hardenability
  用含碳量分类 – 即低碳钢、中碳钢及高碳钢 Classification According to Carbon Contains
  用途 End Usages
  用组织结构分类 Classification According to Grain Structure
  幼珠光体 Fine pearlite
  元素的原子序数 Atom of Elements
  原子的组成、大小、体积和单位图表 The size, mass, charge of an atom,is particles (Pronton,NentronElectron)
  原子的组织图 Atom Constitutes
  原子及固体物质 Atomsolid material
  原子键结 Atom Bonding
  圆钢枝,方钢枝及六角钢枝之形状及尺寸之公差 Tolerance on ShapeDimensions for Round Steel Bar, Square Steel Bar, Hexagonal Steel Bar
  圆径及偏圆度之公差 Tolerance of Wire Diameters & Ovality
  圆面(“卜竹”)发条 Convex Spring Strip
  再结晶 Recrystallization
  正磁化率 Positive magnetic susceptibility
  枝/棒无芯磨公差表 (μ) (μ = 1/100 mm) Rod/Bar Centreless Grind Tolerance
  枝材之美工标准,日工标准,用途及化学成份 AISI, JIS End UsageChemical Composition of Cold Drawn Carbon Steel Shafting Bar
  直径,公差及拉力强度 Diameter, ToleranceTensile Strength
  直径公差,偏圆度及脱碳层的平均深度 Diameter Tolerance, OvalityAverage Decarburized Layer Depth
  置换型固熔体 Substitutional type solid solution
  滞后回线 Narrow Hystersis
  中途退火 Process Annealing
  中珠光体 Medium pearlite
  周期表 Periodic Table
  轴承合金 Bearing Alloy
  轴承合金–日工标准 JIS H 5401 Bearing Alloy to JIS H 5401
  珠光体 Pearlite
  珠光体及共释钢 Pearlite &Eutectoid
  主要金属元素之物理性质 Physical properties of major Metal Elements
  转变元素 Transition element
  自发上磁 Spontaneous magnetization
  自由度 Degree of freedom
  最大能量积 Maximum Energy Product
  (to JIS G3521, ISO-84580-1&2)化学成份分析表 Chemical Analysis of Wire Rod
  305, 316, 321及347之拉力表 Tensile Strength Requirements for Types 305, 316, 321347
  A1S1-302 贰级线材之拉力表 Tensile Strength of A1S1-302 Wire
  Grain Oriented & Non-Oriented 电器用硅 [硅] 钢片的最终用途及规格 End UsageDesignations of Electrical Steel Strip
  Oriented Electrical Steel Sheets
  SK-5 & AISI-301 每公尺长的重量/公斤(阔2.0-10公厘) Weight per one meter long (kg) (Width 2.0-10mm)
  SK-5 & AISI-301 每公斤长的重量/公斤(阔100-200公厘) Weight per one meter long (kg) (Width 100-200mm)
  SK-5 & AISI-301 每公斤之长度(阔100-200公厘) Length per one kg (Width 100-200mm)
  SK-5 & AISI-301 每公斤之长度(阔2.0-10公厘) Length per one kg (Width 2.0-10mm)
发表于 2010-12-30 16:38:27 | 显示全部楼层
好资料!收藏了!
发表于 2012-8-9 10:18:03 | 显示全部楼层
非常好的资料,谢谢喽!
发表于 2012-8-11 13:04:43 | 显示全部楼层
不错,学习学习,天天向上
发表于 2012-8-14 09:35:16 | 显示全部楼层
来学习的!O(∩_∩)O谢谢:)
签到天数: 25 天
发表于 2012-8-16 21:12:05 | 显示全部楼层
谢谢楼主分享。。。正需要,,,
GMT+8, 2026-7-19 06:02 , Processed in 0.031996 second(s), 22 queries .
