查看: 10826|回复: 9
[讨论] 谁能回答下面几个问题吗?(英文版)
发表于 2011-5-5 17:13:59 | 显示全部楼层 |阅读模式
1、Describe the following iron based alloys in terms of the range of compositions (particularly
carbon) and typical mechanical properties.
a. Plain carbon steel e. Gray cast iron
b. Low, medium and high carbon steel f. Stainless steels: ferritic, austenitic,
martensitic
c. Cast iron g. Hypo-eutectoid steel
d. White cast iron h. Hyper-eutectoid steel
2、Describe, in general terms, the composition, structure, mechanical properties and formation
of the following phases found in steels:
a. Ferrite d. Martensite
b. Pearlite e. Austenite
c. Cementite f. Graphite
3、Describe, in general terms, the following standard types of heat treatments in terms of the
processing, microstructure produced, and mechanical properties for steel:
a. Normalize e. Martemper
b. Temper f. Austemper
c. Quench g. Stress relieve
d. Austenitize h. Anneal
4、Why do alloys possessing high hardenability often have poor weldability (usually due to
weld cracking)?
5、What role does carbon play in the formation of martensite?  Can pure iron be austenitized
then quenched to form martensite?
6、How does austenite grain size effect hardenability?
7、What is the A3 temperature and why is it different for  the different alloys being investigated?
 楼主| 发表于 2011-5-5 17:15:09 | 显示全部楼层
期待高手出现哦
 楼主| 发表于 2011-5-6 22:39:42 | 显示全部楼层
求高手:)
发表于 2011-5-7 03:59:13 | 显示全部楼层
内容简单,回答的内容太多,成为作文了,没有那功夫。
发表于 2011-5-7 07:25:41 | 显示全部楼层
内容较简单,纯粹考验英语水平。
发表于 2011-5-8 09:16:48 | 显示全部楼层
呵呵,大二的学生表示都是刚学过的,推荐看一本书,英国皇家科学会的会员Cahn著的,《The Coming of materials science》,需要的话我可以给你电子版的。
签到天数: 69 天
发表于 2011-5-8 19:32:34 | 显示全部楼层
我想要一份《The Coming of materials science》,请发至:stz001@163.com  谢谢。
签到天数: 80 天
发表于 2011-5-9 20:58:54 | 显示全部楼层
好像是课后练习或是考试题
签到天数: 7 天
发表于 2011-6-9 17:09:23 | 显示全部楼层
我想要一份《The Coming of materials science》,请发至:cosmo4411110@163.com  谢谢
发表于 2011-6-10 18:36:04 | 显示全部楼层
谢谢 ,也给我一份吧  lanweike1@126.com
GMT+8, 2026-7-17 17:14 , Processed in 0.031162 second(s), 21 queries .
