查看: 7905|回复: 0
[Solved] Could you help me? thanks
发表于 2011-5-21 12:31:03 | 显示全部楼层 |阅读模式
effective case depth :
effective case depth is  the perpendicular distance between the white layer/steel interface and the point where the hardness falls below 50 HRC or 10 HRC less than the required hardness for tow consecutive readings。what’s this meaning ?
The  ASTM of USA nitride effective case depth defination?
now ,the qustion is the company require us nitride effective case depth hardness is 45-50HRC, is  we reach the 35-40HRC it ok that ?
GMT+8, 2026-6-28 16:09 , Processed in 0.026257 second(s), 21 queries .
