查看: 11347|回复: 8
[书籍] Steel Metallurgy for the Non-Metallurgist
发表于 2011-7-14 17:08:03 | 显示全部楼层 |阅读模式
Author(s): J. D. Verhoeven
Publisher: ASM International
Date     : 2007
Pages    : 225
Format   : PDF
Language : English
ISBN-10  : 0871708582
This book explains the metallurgy of steel and its heat treatment for non-metallurgists. It starts from simple concepts_beginning at the level of high-school chemisty classes_and building to more complex concepts involved in heat treatment of most all types of steel as well as cast iron. This book is THE practicle primer on steel metallurgy for those who heat, forge, or machine steel.
Summary: A must for knifemakers
Rating: 5
Consider this the Cliff Notes of steel metalurgy. It is an invaluable resource for those of us who make knives and other cutting tools. Forging and grinding a great looking knife with good geometry isn't even half of the story; manipulating the crystalin structure of the steel with heat is at least 75% of it. Steel sellection counts somewhat less. This book gives a good "in depth overview" of what steel and other ferrous alloys are, what their properties are, and how those properties can be used and manipulated. It gives an understanding of what is happening to the steel, not just a cookbook intruction of starting at point A and proceeding to the finished product. It gives knowledge of what to do when the cookbook fails and how to modify the instructions to make things come out better. It allows technique to evolve into art.
第一次发帖~~~我不知道论坛有没有这本书~所以要是有的话,麻烦版主通知我删掉~
怎么把文件上传吖??
需要的发邮箱地址~~我发给你~~
签到天数: 296 天
发表于 2011-7-14 18:42:29 | 显示全部楼层
188382262@qq.com
致谢!:lol
签到天数: 2944 天
发表于 2011-7-14 21:08:56 | 显示全部楼层
发帖时上方有附件上传的图标,发帖后可以使用编辑功能更新,删除,增加附件。
如果是图片文件则使用图片上传按钮。图片上传后可以插入在文字中。
签到天数: 311 天
发表于 2011-7-15 08:48:07 | 显示全部楼层
谢谢。qhdygc@163.com
签到天数: 197 天
发表于 2011-7-15 09:07:41 | 显示全部楼层
请楼主把该资料发至本版即可,点击本帖下方的“编辑”即可。
也可以把资料发给版主,由版主替你上传,这种方式比较便捷。
 楼主| 发表于 2011-7-15 12:58:48 | 显示全部楼层
如果是图片文件则使用图片 ...
不行吖~~只能上传1mb的东西。。。过大就不行了~~
参与人数 1热处理币 +20 收起 理由
sdust + 20 感谢上传!
签到天数: 33 天
发表于 2011-7-15 13:38:15 | 显示全部楼层
上传测试:Adobe Reader 10.1软件
签到天数: 2944 天
发表于 2011-7-15 13:41:32 | 显示全部楼层
现已将原单个附件附件上传大小设置为最大100M,经测试可以正常上传。
这样小于100M的文件可以直接上传。大于100M的文件请打包压缩后上传。
较大的附件由于上传时间较长,请耐心等待。在网速不好的条件下建议还是使用原来的单个压缩包上传的形式,以提高上传成功率。
 楼主| 发表于 2011-7-15 13:43:57 | 显示全部楼层
这样小于100M的文件可以直接上传。 ...
嗯~~~好的~~~谢谢~~先试试~
GMT+8, 2026-7-17 03:11 , Processed in 0.033158 second(s), 23 queries .
