查看: 8910|回复: 7
[Help] 请各位高手帮忙看一下
发表于 2012-2-6 14:53:32 | 显示全部楼层 |阅读模式
Required equipment for producing metal cord:
1.        Dry type drawing machines
1.1.        11 blocks - 5 machines. Inlet diameter -  2,7-3,5mm. Outlet diameter 0,8-1,5mm.
1.2.        12 blocks with mechanical descaling  - 2 machines. Inlet diameter-  5,5-6,5mm. Outlet diameter 1,6-1,8mm.
1.3.        14 blocks with mechanical descaling - 2 machines. Inlet diameter -  5,5-6,5mm. Outlet diameter 1,2-1,8mm.
1.4.        7 blocks - 1 machine. Inlet diameter 5,5-6,5mm. Outlet diameter 2,7-3,2mm.
2.        Device for brass plating, 40 threads. Thread diameter 0,8-2,5mm. DV = 92. Main diameter – 1,7 mm, capacity 16-18 000 tons per year
3.        Patenting line, 20 threads. Diameter 2,7-3,2.
4.        Copper plating line, 20-24 threads. DV = 300, diameter 0,83-1,5mm.
5.        120 sets of wet type drawing machines. Take up (winding) reel - 80 kgs. Inlet diameter - 0,8-2,5mm. Outlet diameter 0,15-0,75mm.
6.        Machines for metal cord twisting
6.1.        Cord structure 4+3 - 160 machines. Take up (winding) reel – 80kgsг. Metal cord: 2x, 3x, 4x, 2+1x, 2+2x, 3+2x, 4+3x. Wire diameter 0,20-0,40mm.
6.2.        Cord structure 3+9 – 18 machines. Winding reel – 80 kgs. Metal cord: 3xD1+6xD2, 3+9xD, 3xD1+9xD2. Wire diameter 0,15-0,45mm.
6.3.        Cord structure 1+18 – 6 machines. Take up (winding) reel – 80 kgs. Metal cord: 1xD1+6xD2+12xD2.  Wire diameter 0,2-0,45mm.
Take up reel for all cable twisting machines BS40, BS60 and BS80.
Material : carbon steel,  carbon content 0,65-0,90%
 楼主| 发表于 2012-2-6 14:59:09 | 显示全部楼层
客户说是钢帘线的热处理,钢帘线用在子午线轮胎的胎面和胎体部,可承载汽车在长时间高速行驶中轮胎所受到的极度压力。
大家有间过这种热处理设备吗?推荐一下厂家
发表于 2012-2-8 11:54:06 | 显示全部楼层
sz.xinling 发表于 2012-2-6 14:59
客户说是钢帘线的热处理,钢帘线用在子午线轮胎的胎面和胎体部,可承载汽车在长时间高速行驶中轮胎所受到的 ...
帘线方面的钢丝一般都是专机,比如说铅浴,油淬火回火(oil-tempered),这个方面的都属于专利性的
发表于 2012-2-8 12:35:57 | 显示全部楼层
1.干拉机器(即皂粉拉拔)
1.1 11道次-5台拉机,输入(原料尺寸)直径-2.7-3.5mm,输出直径(产品尺寸) 0.8-1.5mm。
1.2 12道次带有机械除锈(行业说法叫机械除磷)-2台拉机,输入直径5.5-6.5mm, 输出直径1.6-1.8mm。
1.3 …参照1.3条的翻译
1.4 同上
2. 设备铭牌, 40条线。穿线直径0.8-2.5mm。DV值=92,主要尺寸-1.7mm 产能:16-18 000         吨/年。
  注:DV值为拉拔专用词汇,D为直径(mm) V为速度(m/min)。DV值为设备属性,即根据不同的产品直径换算不同的钢丝速度。
3. 铅浴处理(此处理根据资料分析应该为铅浴退火处理,消除拉拔后的应力),20条线。直径范围2.7-3.2.
4. 镀铜线(设备),20-24条线,DV=300(同第二条解释)。直径0.83-1.5mm。
5. 120台湿拉机器(一般来说,湿拉机的润滑剂为油)。收线盘(线卷)-80KG。输入直径-0.8-2.5mm, 输出直径 0.15-0.75mm
6. 这里的设备我不太了解。不敢乱翻译。这里的take up/winding 解释为收线。大约说的是:
   金属盘收线机
   6.1 收线盘结构4+3 160台机器, 线盘重量80KG:  金属线:2x, 3x, 4x, 2+1x, 2+2x, 3+2x, 4+3x. 线直径0,20-0,40mm.
   6.2 同上。
   所有电缆捻丝机收线盘采用 BS40 BS60 和 BS80型号 (此处的应该是收线盘的规格-工字轮?)
材料:碳钢类,含碳量0.65-0.90%
发表于 2012-2-8 12:41:15 | 显示全部楼层
搞错了,不是求翻译的啊
你说的设备,一般都是自主设计的,只有一些专用部件是标准件,话说前段时间正好参与设计了类似的设备。
而你提供的资料显示,这不仅仅是设备,而是一条生产线啊。
能不能透露一下客户的信息?
 楼主| 发表于 2012-2-8 12:43:42 | 显示全部楼层
luoyacao 发表于 2012-2-8 12:35
1.干拉机器(即皂粉拉拔)
1.1 11道次-5台拉机,输入(原料尺寸)直径-2.7-3.5mm,输出直径(产品尺寸 ...
翻译的这么详细,非常感谢
以后请多指教了
谢谢
发表于 2012-2-8 12:47:51 | 显示全部楼层
sz.xinling 发表于 2012-2-8 12:43
翻译的这么详细,非常感谢
以后请多指教了
谢谢
你是做设备生产的吗?说不定有机会自己开厂子,还要求助你呢
签到天数: 98 天
发表于 2012-2-8 16:46:59 | 显示全部楼层
做弹簧钢丝厂都有这种设备!
GMT+8, 2026-7-16 19:40 , Processed in 0.031476 second(s), 21 queries .
