查看: 9125|回复: 1
[Help] 意大利比亚乔热处理标准
签到天数: 165 天
发表于 2012-2-17 17:10:15 | 显示全部楼层 |阅读模式
It is the distance between the external surface and the point on which Vickers hardness assumes the conventional value of HV = 685 (HRC ~ 59).It is determined as per point 2.1.1
The hardened surface may be approximately evaluated, with the help of a centisimal comparator with 20 magnification, considering the area (on a transversal section of the piece) including the external surface and the point on which the coloring of the surface etched by the reactive agent, change from blue to brown - yellow.
The section of the piece is polished and etched with reactive agent Nital 4% for about 30 seconds。
签到天数: 96 天
发表于 2012-2-18 11:06:29 | 显示全部楼层
这是从表面处到传统意义上假设的维氏硬度值为685(HRC-59)测定点的距离。
这是每个点被确定的方法。
The hardened surface may be approximately evaluated,with the help of a centisimal comparator with 20 magnification,considering the area (on a transversal section of the piece) including the external surface and the point on which the coloring of the surface etched by the reactive agent, change from blue to brown - yellow.
在20倍比较仪器的帮助下,被硬化的表面可以粗略的计算,考虑的区域(在一个横截面上)包括外表面和这个点,在活性剂的酸蚀下,从表面到这个点的颜色从蓝色变为棕黄色。
切割件抛光后用4%的硝酸酒精溶液腐蚀30秒。
水平有限,仅供参考!
GMT+8, 2026-7-16 20:30 , Processed in 0.035207 second(s), 24 queries .
